1981 kz 750 forks
  • baldguy
  • baldguy's Avatar Topic Author
1981 kz 750 forks
09 Mar 2009 15:52
#270670
Could anyone tell me what the stock length of the forks are on a 1981 750h are.This one seems to be over stock length and I have slid them up the tree to the handle bars and it still sits real high.Thanks
  • l0g1c
  • l0g1c's Avatar
  • Hanging on for dear life.
Re: 1981 kz 750 forks
09 Mar 2009 16:05 - 09 Mar 2009 16:08
#270676
I won't be home for a while, but if you don't get an answer before then, I can go measure mine. Did you just want end-to-end?
Oh, and the LTD has a 19" front wheel and 16" rear, which may be another reason it sits high.
'81 KZ750 LTD
'72 CB350K
Omaha, NE
Last edit: 09 Mar 2009 16:08 by l0g1c.
  • baldguy
09 Mar 2009 17:16
#270712
Yes end to end This thing seems to be way high in the front.On the kick stand it looks like its going to fall over.
  • l0g1c
  • l0g1c's Avatar
09 Mar 2009 18:02
#270727
You got it. It will probably be sometime tomorrow evening before I can get to it (literally).
'81 KZ750 LTD
'72 CB350K
Omaha, NE
  • JMKZHI
  • JMKZHI's Avatar
09 Mar 2009 19:00
#270748
~35" from the bottom of the lower tube to the top of the upper tube. Add an inch for the fork cap.
  • baldguy
10 Mar 2009 04:09
#270859
Thanks for the reply
