Brake Lines?
- Wallybanger
Brake Lines?
05 Mar 2009 23:04 - 07 Mar 2009 18:05
I've got a 1980 KZ750H1 LTD. Anyone familiar with this thing knows that there is a break line going from the master cylinder to a splitter right under the headlight and then 2 brake lines going down to the calipers.
I want to make new breaklines for this beast but it's getting cost prohibitive for 3 SS lines. I'm wondering if I can get away with 2.
Run one from the master to the right caliper and then use the double banjo bolt from the splitter to run another line from the RHS Caliper over to the LHS caliper.
I haven't had a look inside that splitter yet but i doubt there are any safety mechanisms in there and PV/T seems to be telling me that doing this won't change anything.
Anyway, at $20 an end an $11/foot for SS line, 2 lines is definitely better than 3. Just thought I would post here to see if anyone might want to dissuade me for one reason or another...
Last edit: 07 Mar 2009 18:05 by KZQ.
- donthekawguy
Re: Brake Lines?
06 Mar 2009 00:18 - 07 Mar 2009 18:06
The spiltter should have the switch to turn the brake lamp on when you pull the lever. You can get Russell lines at Denniskirk.com that you put together. You can buy what you can and do one part at a time. But you should do both lower lines going to the calipers at the same time.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
Last edit: 07 Mar 2009 18:06 by KZQ.
Last edit: 07 Mar 2009 18:12 by KZQ.
Re: Brake Lines?
06 Mar 2009 09:49 - 07 Mar 2009 18:11
donthekawguy wrote: "The splitter should have the switch to turn the brake lamp on when you pull the lever."
I think your bike is different than the bikes (like mine) that had this setup. I believe your brake lamp switch is integrated into the master cylinder. You should check. Ed
Last edit: 07 Mar 2009 18:11 by KZQ.
- Wallybanger
Re: Brake Lines?
06 Mar 2009 12:42 - 07 Mar 2009 18:11
Yeah, my break switch is in the master and I'm actually replacing it with a banjo bolt switch.
My question still hasn't really been answered....
- BSKZ650
Re: Brake Lines?
06 Mar 2009 12:47 - 07 Mar 2009 18:10
the answer, no you dont want to do that, one caliper will brake harder than the other.the splitter divides the fluid first, then sends it on the way, keeping the presure even to both calipers
77 ltd1000, current rider
76 kz900, just waiting
Last edit: 07 Mar 2009 18:10 by KZQ.
- Locozuna
Re: Brake Lines?
06 Mar 2009 13:04 - 07 Mar 2009 18:10
I think the double banjo bolt is in itself a splitter and cannot see how one side should be more pressure than the other. Please explain. I'm no fluid dynamics expert so I can't say for sure but it seems to me if the hoses are the same length and coming off the same piston? One banjo might be 1/4 to 1/2 an inch longer from the piston because of the bolt but will this make a real difference in a closed circuit? Interesting.
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
"If you seek for Eldorado!"
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
- mark1122
- Keep twisting it
Re: Brake Lines?
06 Mar 2009 14:57 - 07 Mar 2009 18:09
I may have the answer u seek yonge Jetie. PM me soon.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Last edit: 07 Mar 2009 18:09 by KZQ.
- 893cv
Re: Brake Lines?
06 Mar 2009 15:37 - 07 Mar 2009 18:08
The answer, yes that will work just fine. Both Triumph and Suzuki do two line systems that way on thier sport bikes. I beleave the thinking is that the less flexable brake line used in a system the better the feel. I've done the one line down and then a jumper to the other caliper, brake lines for years.
Good Luck!
Good Luck!
1980 kz1000 LTD
1978 Z1R
1978 Z1R
Last edit: 07 Mar 2009 18:08 by KZQ.
- mark1122
- Keep twisting it
Re: Brake Lines?
07 Mar 2009 05:38 - 07 Mar 2009 18:08
If u have a switch at the lever then u dont need the stock splitter/ braek lt switch at all.
u can run 1 line each, from the master to each side.
or u can run 1 from the master to the right cal and then a second from the right cal to the left cal.
I have a stock length, 3 line set up in braided steel if u are interested.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- Wallybanger
Re: Brake Lines?
07 Mar 2009 14:31 - 07 Mar 2009 18:07
Thanks guys. I was pretty sure it would work fine and I knew it had been done on other bikes. Just thought I would ask here first just to be sure.
Mark, I hadn't thought about doing 2 lines from the master but that is actually a fine idea. I'm wondering which one will be harder to bleed :blink:
How many millions to do you want for your stock steel lines? I think it may be a tough sell at this point
(Oh, I was lookin at your bike in your profile pic... it looks SWEET!)
Last edit: 07 Mar 2009 18:07 by KZQ.
- mark1122
- Keep twisting it
Re: Brake Lines?
07 Mar 2009 14:41 - 07 Mar 2009 18:06
Thanks.
I am ordering the 2 line from the master setup for mine. i played with some lines and it seems that it will be nice to route the lines this way. i didn’t like the 1 line going from cal to cal due to the fact that there is nothing to hold the line in place. just my opinion.
PM me for a $. I haven’t figured that out yet. could u see then in my project post?
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
