Wheel spacers...steel-braided lines...
  • racer54
  • racer54's Avatar Topic Author
04 Mar 2009 17:55 - 04 Mar 2009 18:20
#269708
When you guys mount those wide rims, where do you get your wheel spacers? Or what do you use for spacers? Couple guys around here I've talked to who are racers and build bikes are claiming it will cost around $200 to mill some and that is insane. Anybody here able to make some or point me in the right direction to someone who does?
Last edit: 04 Mar 2009 18:20 by racer54.
  • kano
  • kano's Avatar
  • Not Another Bloody Limey!
Re: Wheel spacers...
04 Mar 2009 17:58
#269709
i have cut them down and filed them,
or you can get some from this guy.
stores.ebay.com/Billet-Cycle-Parts-Las-V...Q3amefsxQ3asstQQtZkm
  • racer54
04 Mar 2009 18:19
#269716
Cut down stock spacers? I thought about doing just that but I'm not to that point yet but trying to look ahead. The prices from that guy sure sounds more reasonable. I know J&P sells some but not sure of the size. Local racer says axles are usually either 3/4" or 20mm. Not sure how much difference between the two though. How much clearance canyou get away with on spacers? Ex. can you use a 1" i.d. spacer for a 3/4" axle? Beings it's just a spacer, does it matter that much?
While we are at it...where is a good place to get steel-braided lines made? Talking brake lines mostly. Any companies make them to size or would you have to buy whatever is close and make them work?
  • kano
  • kano's Avatar
04 Mar 2009 18:31
#269722
you would be surprised what you can get away with tolerances on spacers lol i have a triple tree nut as a space on my rear wheel been on there 15 yrs.:blush:
brake lines is where i am at right know,
i would like to cut them my self rather than measuring.
not sure if you can build your own lines but i used to back in the uk.
  • gane
  • gane's Avatar
04 Mar 2009 18:41
#269725
Brake lines, Russell has been a standard for years and make kits for mote everything, They also sell fittings for those who feel competent at building their own. Earl's Automotive also sells B/S and fittings and can be order'd thru Napa.G
[img][/img] 1977 KZ1000A1
04 Mar 2009 23:55 - 04 Mar 2009 23:57
#269771
Z1E has a wide selection of brake hoses including various types, sizes and fittings.
Click here > Z1E Brake Hoses
The stainless steel braided style begins on page 6.
Good Luck! :)
Last edit: 04 Mar 2009 23:57 by Patton.
  • donthekawguy
  • donthekawguy's Avatar
Re: Wheel spacers...steel-braided lines...
05 Mar 2009 04:05
#269778
Dennis Kirk has the Russell lines you can put together yourself. Just measure and look up the parts. They sell the lines and screw on fittings. I used a set on my 78 and they worked out great. As for spacers, I was thinking about buying one of those cheapy lathes from Harbor Freight and start making them. The lathe is cheap and probably not good for anything heavy duty but would work for spacers. Just buy a 2 inch solid bar and a good set of micrometers and go to town.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
06 Mar 2009 09:37
#270036
i can help you out on those spacers.i have a lathe and the ability to run it:laugh: .shoot me a pm if i can help.
leon holmes
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
06 Mar 2009 15:05 - 06 Mar 2009 15:07
#270075
What size spacer do u need. i bought an extra for my zrx axle and had it milled down.
U can find the proper I.D. spacer for your axle, on bike bandit .com and have it altered to fit. pm me if u need info. I also have spare braided lines.B)
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Last edit: 06 Mar 2009 15:07 by mark1122.
  • racer54
06 Mar 2009 16:35
#270089
Not sure what sizes I will need yet. Getting ready to tear into it in a few days. Have a couple bikes I will need them for but I will remember the offers when I get that far. Appreciate the help. Sort of starting from scratch on one of them so it might be a while for that one. I know I'll need them for the front and rear axles though. Depends on which wheels I use.
  • MFolks
  • MFolks's Avatar
06 Mar 2009 16:51
#270095
For light weight spacers some 6061-T6 or 7075 Aluminum will work. 1018 steel is strong but is heavier than the others. For a selection of material go to www.onlinemetals.com
  • OnkelB
  • OnkelB's Avatar
07 Mar 2009 12:06
#270238
$ 200? :blink: Sorry, but those guys need to put the pipe down - when I put a Zephyr 750 swingarm in my 650 my local friendly machine shop made me a 17 mm pivot bolt, a rear axle and three rear wheel spacers (one left, one right and one between hub and sprocket hub) all in stainless to the tune of $ 75. Yeah, I'm in Europe but still.
A wheel spacer is nothing but a piece of pipe meant to keep the wheel positioned sideways, anyone who knows how to operate a lathe should be able to make you a set in 15 minutes or less.
77 KZ 650 B1, 82 GPz 1100 B2.
