1974 Z1 900 rear master cylinder mount
  • oldkaws4ever
  • oldkaws4ever's Avatar Topic Author
  • Have no regrets...... You only live once.
03 Mar 2009 12:19
#269437
I am putting on triple disc mag wheels on my z1 900, what thickness metal should i use for the rear master cylinder mount? I am going to bolt it off the right rear motor mount, and the master cylinder is off of an 03 suzuki gsxr 600 with the remote resovour. Thanks, jim.
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
  • PLUMMEN
  • PLUMMEN's Avatar
Re: 1974 Z1 900 rear master cylinder mount
03 Mar 2009 17:20
#269493
i think the one on my 74 was made from like 20 ga or something like that cant remember for sure.ive still got the chrome battery box for ya just never have time to sit down long enough to box it up and ship!:S
  • oldkaws4ever
03 Mar 2009 20:38
#269520
lol, its ok plummen when ever you have enough time. @0 ga seems like it wiould hold up well enough, thanks.
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
  • StreetfighterKz
  • StreetfighterKz's Avatar
04 Mar 2009 04:15
#269550
The mount I made for my 900 is something like 3/32" mild steel with a couple nuts on the back to bolt the M/C to.
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
  • tw..
  • tw..'s Avatar
04 Mar 2009 06:27
#269587
Very nice setup Doug. That's what I want to do but for some reason I can't bring myself to weld or alter my frame, however I've been considering it more and more.
2-1976 KZ900 A4
1995 KZ1000 Police bike
1978 Z1R
  • wiredgeorge
  • wiredgeorge's Avatar
04 Mar 2009 06:33
#269590
I had welded a stock mount cut off another bike in the stock location that is quite a bit higher than shown because I used a stock-type master cylinder. It takes one of those rods to poke the center of the plunger upwards when the brake pedal is pushed. I later mounted a Ninja 250 master cylinder which looks much like StreetfighterKZ posted and had to fab a bar to attach to the master cylinder and brake pedal... the one he did is in a much better position anyway, because on the Z1, you won't be able to pull the battery out the side with the master cylinder mounted where it would be on say a 77 or 78 with rear disk brake. You have to pull the battery out from the top which means cutting your battery box a bit.
  • PLUMMEN
  • PLUMMEN's Avatar
04 Mar 2009 07:33
#269608
on all the z1s ive ever had battery pulled out through the top,76 kz900 was on bike i ever had that side loaded behind sidecover.B)
  • wiredgeorge
04 Mar 2009 10:45
#269644
I guess I was thinking about the KZ900... they all sort of fog when you have heards of them.
