Steering stem interchangability?!?!
- twowheeledterror
27 Feb 2006 18:43
Okay, need to find this out.
What other KZ's had identical stems to a 79 KZ650? Some of the 750's perhaps?
I need to track down a lower triple to press the stem out of so I can press it into the from forks I've got and mount it all to the frame.
Thanks!
Thanks!
- OnkelB
Re: Steering stem interchangability?!?!
28 Feb 2006 07:35
I uploaded a Kawasaki steering stem bearings list a while back, here are a couple of links to it:
List as Word document:
kzrider.com/component/option,com_docman/...ad/gid,241/Itemid,5/
List as PDF:
kzrider.com/component/option,com_docman/...ad/gid,242/Itemid,5/
Note that the list will only show which bikes share the same stem diameter, the length of the stems may vary.
List as PDF:
77 KZ 650 B1, 82 GPz 1100 B2.
- steell
28 Feb 2006 07:56
I have both a 650 and a 750B steering stem with lower clamp, I'm on my way out the door right now but I'll try to get time to measure the length later. It would be easier for me if you would measure the length of the neck on the 650 though, it's easier for me to measure the neck on a 750B frame than to dig out the steering stems
- twowheeledterror
28 Feb 2006 23:11
The neck on the 650 is 7.5" long.
Let me know what works.
- ran429
- Master of FREE rides!
01 Mar 2006 20:49
twowheeledterror wrote:
1981 kz750E is the same
And diameter of the shaft is aprox 1-1/8 wide.
I measured my parts bike steering head from lip to lip with the tripples out/ no bearings
Post edited by: ran429, at: 2006/03/01 23:50
- twowheeledterror
01 Mar 2006 21:47
Thanks man!
So it sounds like any 650 and any 750 should work out.
