white flaky master cylinder
  • ccentralm
  • ccentralm's Avatar Topic Author
28 Feb 2009 15:43
#268726
i bought a master cylinder off ebay. its all flaky like aluminum gets when it oxidizes and im wondering if its still useable or if i need to get a new one because its been exposed to moisture on the inside.
1982 Kawasaki KZ 750LTD. i wanted the big boy 1000, but there's like a billion of these 750 ltds running around. so what the hey!
  • ccentralm
Re: white flaky master cylinder
28 Feb 2009 15:49
#268731
also, if i cant use this one, what other models that used a dual front rotor setup can i swap with? kz 1000? 1100?
  • ccentralm
01 Mar 2009 05:56
#268866
bump
01 Mar 2009 06:17
#268874
If the bore is not too pitted, could likely be restored to serviceable condition. May or may not require new cup(s), piston, and/or other parts. Is it an oem part? What bike and model is it from? Is it intended for the 1982 Kawasaki KZ 750LTD shown in signature?
Good Luck! :)
  • ccentralm
01 Mar 2009 06:26
#268879
yes its intended for the bike in the signature and it is also from a kz 750 ltd. so the bore is the only thing i have to look at to see if its still useable? it is oem.
01 Mar 2009 06:42
#268886
If needed, here's the parts diagram from kawasaki.com. :)
[Click on image to enlarge view]
  • ccentralm
01 Mar 2009 06:53
#268891
yes, ive got the assembly part number memorized - 43015-1046 - and i see the kz 1000 of the era has a matching MC part number as well. ive been scouring ebay and have found a few questionable pieces that would work, though in rough condition. ill check the bore on it later today, if the bore is in decent condition do i need to worry about the white aluminum flakes or do i just toss my brake fluid in there?
  • fixer5000
  • fixer5000's Avatar
01 Mar 2009 07:08
#268896
why not clean out all the white flakes?? rebuild it and use some fine scotchbrite on the resevoir and the bore
1978 kz650b pretty much stock
massachusetts
  • ccentralm
01 Mar 2009 07:22
#268899
i just needed a green light from someone to know that its still okay even with the oxidized aluminum.
01 Mar 2009 11:44
#268963
When working with the m/c disassembled on the workbench, I enjoy using a bottle of common household rubbing alcohol as a cleaning agent, with hand-squeeze spray attachment. Blow dries without undesireable oily residue.
Compressed air is also handy, and of course reassemble with interior parts doused in clean new brake fluid.
If any part needs replacing, it's likely the piston assembly (comes with rubber cups already fitted) available at Z1E Piston Assembly which I believe corresponds with the diagram part number 43020.
Good Luck! :)
  • trianglelaguna
  • trianglelaguna's Avatar
01 Mar 2009 12:54 - 01 Mar 2009 12:56
#268976
Patton wrote:
I enjoy using a bottle of common household rubbing alcohol as a before dinner drink to relax......then i slip into somthing comfortable......usually silk ...becuase it's sheek but not too sheer.....then put on some culture club and just let it all go.....
triangle wrote;
jeeze patton he just want his brakes fixed com'on fella...jeeze:woohoo:
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
Last edit: 01 Mar 2009 12:56 by trianglelaguna.
  • riverroad
  • riverroad's Avatar
  • 1980 1000LTD B4
02 Mar 2009 10:50
#269238
Naw, Patton ain't into Culture Club anymore.
He's more into:
:woohoo:
