16" front wheel?
- Jimbo302
16" front wheel?
27 Feb 2009 10:36
Are there any 16" front wheels that would replace the 19" on a 76kz900 ltd?
- StreetfighterKz
Re: 16
27 Feb 2009 11:18
I think some of the Gpz600/900 had a 16" front rim but I don't think your stock forks are going to be wide enough to fit the rim in. What's the reasoning behind you wanting a 16" front rim?
Later, Doug
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
- franknsr
Re: 16
27 Feb 2009 18:02
Don't know about Jimbo but I was after a 16" front because I like the way it looks.
Formerly CSRchopper
1991 KZ1000P
Gone but not forgotten
1986 ZG1000
1982 650 CSR -shoulda kept this one-
Lisle Illinois, USA
1991 KZ1000P
1986 ZG1000
Lisle Illinois, USA
- trianglelaguna
Re: 16" front wheel?
27 Feb 2009 19:23
a lot of guys that had 16 inch front tires got to look at em .....real close..... as they slid by the bike on their stomach coming out of corners.:laugh: :woohoo: beware the 16" fronts...and any emergency brake grabs
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
2003 ZX12R
2007 FZ1000
- Jimbo302
Re: 16
09 Sep 2009 14:44
trianglelaguna wrote:
The smaller wheel doesn't work well with the geometry of the bike?a lot of guys that had 16 inch front tires got to look at em .....real close..... as they slid by the bike on their stomach coming out of corners.:laugh: :woohoo: beware the 16" fronts...and any emergency brake grabs
- trianglelaguna
09 Sep 2009 15:04 - 09 Sep 2009 16:08
less straight line stability and eratic transitions...a tendency to tuck and wash out entering corners on the brakes....it is all relative...i mean a proper set up 16 worked into the front end as opposed to a sucky 19 set up would still be better.....the big four tried this on models in the 80's to help with side to side quick transitions ....then went back to 18 then settled on 17's for most bikes today..
our bikes ..rake/frames/engines/wheelbases/and traction requirements...were designed for a straight line stability and can corner ok ,given a second to roll up and over in transition.....many frame kits back in the day were actually a step backwards from a stock lay out... even though they "looked" cool....early 73-82 kz's seem better suited to 19 and 18 tires.....on a stock front that is...the pay off to a switch in rim size up front..is a big bit of work in most casses...not just a rim switch and fender mount change.....imo
1976 KZ900
2003 ZX12R
2007 FZ1000
2003 ZX12R
2007 FZ1000
Last edit: 09 Sep 2009 16:08 by trianglelaguna.
- RonKZ650
09 Sep 2009 16:16
16" didn't work even on a motorcycle designed for it. I had a Honda interceptor back in 1983 with the 16" and was extremely lucky to have not crashed it. Very unforgiving. One speck of oil under it or gravel and you're in deep shit. Stay 19"
- donthekawguy
09 Sep 2009 23:12
I put a 18 on mine and with the longer gs arm the thing rides smooth as glass and handles a lot better.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
- Jimbo302
Re: 16
10 Sep 2009 14:17 - 10 Sep 2009 14:21
donthekawguy wrote:
An 18" front? or do you mean the 18" rear, I assume? If so where did you get your wheel? Was it a direct fit?I put a 18 on mine and with the longer gs arm the thing rides smooth as glass and handles a lot better.
Last edit: 10 Sep 2009 14:21 by Jimbo302.
- will61310
Re: 16
10 Sep 2009 15:25
i think the cop bikes had 18 in fronts - you can check ebay for one. and if im not mistaken they are a tad wider as well
...1980 LTD 1000...
- BohicaBob
- donthekawguy
Re: 16
10 Sep 2009 23:25
Jimbo302 wrote:
I got an 18 inch excell up front and a 18x5.5 inch akront in the rear. I got the front from buchanons and the rear off ebay.
donthekawguy wrote:An 18" front? or do you mean the 18" rear, I assume? If so where did you get your wheel? Was it a direct fit?I put a 18 on mine and with the longer gs arm the thing rides smooth as glass and handles a lot better.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
