Z1 900 Front fork rebuild
- oldkaws4ever
- Have no regrets...... You only live once.
25 Feb 2009 23:25 - 26 Feb 2009 02:07
Ok, im ready to get rolling on my fork rebuild, im getting a set of new never used progressive fork springs from a member here. Im ordering the fork seals and dust covers along with a long list of goodies from jeff at z1. Are there any special tools i will need to rebuild them? Thank's Jim
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
Last edit: 26 Feb 2009 02:07 by oldkaws4ever.
- shighley
Re: Z1 900 Front fork rebuild
27 Feb 2009 06:21
Hey Jim; I just went through this on my Z1A. You will need a pick type probe to remove the wire retainer on the seal. I usually remove the old seal by cutting it (carefully) with a small cold chisel. Others use prying type tools and I always end up with dents in the aluminum housing. Anneal the lower sealing washer and reuse it. Heat to cherry red and quench in cold water. Keeping the damper from rotating while torquing the lower bolt is sometimes an issue. I usually run it in with a 3/8 impact (set on low!) and hex driver and then torque to spec. Use a 6 point socket on the cap so it doesn't get marked up. Pretty straight forward all in all. Good luck, Steve
\'74 Z1-A, Bought new, worn out 3 times, being ridden now
\'83 XVZ12TK, was daily driver until frame broke
\'78 KZ650SR-D1A, Son's bike, I'm the wrench (He's young)!
- oldkaws4ever
27 Feb 2009 08:58
Thanky you shighley, now i just need to order my parts and get rocking.
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
