Swapping mag wheels to spoked wheels
  • iandz500
  • iandz500's Avatar Topic Author
25 Feb 2009 10:45
#268033
I have a 1980 Z500B with mag wheels on it but i'm trying to go down a cafe racer route, does anyone know if any kawasaki spoked wheels will fit straight on?
and also would i need to change to use old brakes or could i refit my 3 disk set up?
Thanks
Iand
Bikes: 1960 lambretta Li125 sold; 2001 Honda CG125 sold; 2006 Yamaha FZ6 sold; 1980 Kawasaki Z500 sold; 1967 BSA Bantam D10; 2008 Aprilia Shiver sold; 2010 KTM Duke 690R; 1954 BSA Bantam; 1980ish Kawasaki Z200
  • gorack
  • gorack's Avatar
Re: Swapping mag wheels to spoked wheels
25 Feb 2009 10:57
#268037
front spoked wheel off a 650/750/1000 should bolt on. but the rear is a little more challenging, im assuming your bike has a 18' rear with a disc akz750 twin or a kz 1000 wheel will work but it uses a 20mm axel and yours is a 17mm. you can either change swingarms or open up the slots in your swingarm, or possibly change the bearings in the wheel too fit a 20mm axel
  • iandz500
25 Feb 2009 11:08
#268040
nice one thanks for the quick reply gorack!
will my twin discs fit back on the the spooked wheel?
  • The Gringo
  • The Gringo's Avatar
  • ¡Usted no necesita otra motocicleta!
25 Feb 2009 11:36
#268043
Sorry to dash your hopes but the short answer is no, nothing I can think of will fit as to bolting right on. The 650/750/900/1000 with spoke wheels used a larger diameter axle as well as not being leading axle forks like you now have. Same thing in the rear the 750 and the 1000 with rear disc and spoke wheels both used larger rear axles than what you currently have. Also the manner in which your discs mount to your wheels is totally different than the setup used on the wheels you are thinking of trying to bolt on.
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
KZ 550 times 2 80 440LTD-Sold
  • JMKZHI
  • JMKZHI's Avatar
25 Feb 2009 12:00
#268051
Gringo, does the Z500 have the same front wheel as the KZ550s in the USA?
  • gorack
  • gorack's Avatar
25 Feb 2009 13:20
#268063
how about a csr 1000 front wheel, just a thought-gringo?
  • The Gringo
25 Feb 2009 14:01
#268074
As far as I know if it has a dual disc front end it would be more like our GPZ550 in that the discs bolt to the wheels with I think 7? allen bolts per side. The LTD and the 550 std. we got here were only setup for one disc on the LH side.
gorack how about a csr 1000 front wheel, just a thought-gringo?
That would be about the only possible front wheel that might work although I'm unsure if they used the same small axle size that the 550's and 650 CSR's used. I do know that the front disc used on the 650 CSR's were unique to that model.
Since iandz500 is in the UK I'm sure he would have a hard time sourcing any CSR parts since they were not sold there. This is just one of those really tough things to do without changing over the complete front end and the rear swingarm as well.
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
