KZ1000 fork question
- riverroad
- 1980 1000LTD B4
25 Feb 2009 05:02
Are there any differences in forks between models and years 1978 to 1980?
Mine's an '80 B4, and I'm looking for some good forks to rebuild to put on my bike.
Figured while I'm at it, I'd go ahead and put some new neck bearings in (low speed wobble/detent). Will I need any special pullers or anything?
- RonKZ650
Re: KZ1000 fork question
25 Feb 2009 06:45
It looks to me like the KZ1000B was all the same from 1977-80. Get a seal puller if you're replacing seals. Makes the job much easier. Otherwise just a hammer and a drift punch will knock out the old bearings. Of course the old broom handle holder tool to remove the bottom allen bolts from the fork legs or impact driver will be needed to disassemble the legs.
- riverroad
- 1980 1000LTD B4
25 Feb 2009 06:52
Thanks Ron. Happen to know if there's a difference between A and B? I'm lookin at a set, but they don't specify what model KZ1000. Just that they're from a '78.
Yeah, I was just looking at some other threads on this subject, and the broom handle sounds easy enough. If not, my welder is on standby.
I'd rebuild my own, but mine have some rust.
- RonKZ650
25 Feb 2009 06:56
It looks like 1978A was the same too. 1977A would be different and the 1979-80A had the black legs.
- riverroad
- 1980 1000LTD B4
- roy-b-boy-b
26 Feb 2009 03:04
Google "forks by frank" (i think that's right)
Might be a better option of having new tubes. I have a 1980 front end and it has a few blemmishes on the legs. I'll probably end up using them on the drag bike as it has no suspension. Roy
- riverroad
- 1980 1000LTD B4
26 Feb 2009 05:34
Thanks Roy, but I just bought a used set of forks on fleabay. Should be here Saturday. Hopefully they're nice and straight and as pretty as described. Now I'm going to order some seals and dust covers and some new neck bearings.
The only reason I'm replacing my forks is because mine have some of that unsightly rust on them. I plan on rebuilding and polishing the new forks so they're ready to swap in. Trying to avoid a whole lot of down time.
I did see a set of KZ forks for sale with Franks tubes on them, but they were extended.
- wiredgeorge
26 Feb 2009 08:06
The 79/80 KZ1000E1/E2 used 41mm fork tubes and was unique in that. The other models used a different size I believe.
26 Feb 2009 09:07
- riverroad
- 1980 1000LTD B4
02 Apr 2009 08:07
Well I got these forks a month ago, and haven't had time to mess with them. I have everything I need now except one thing.
I want to make that tool that holds the thing still while I turn the bottom allen bolt out. Someone said he welded a nut onto a piece of all-thread?
What size nut?
I've decided not to use the lowers that came with these forks, because mine are in better shape. Tubes are great though.
I also noticed that on one of my original 1980 forks, there's an extra casting with a small threaded hole in it. Maybe 3mm.
The lower from the 1979 I just bought doesn't have this casting. If I remember correctly, the casting is on the speedo drive side. L/h
Anybody know what this casting is for?
What size nut?
02 Apr 2009 09:54
Is it the little tab thing for the fender stay?
- timebomb33
02 Apr 2009 10:44
the nut size that you can use is 17mm and the little hole your talking about is for the speedo cable guide.
I THINK MY POWERBAND BROKE
