Help with points housing
  • austin3119
  • austin3119's Avatar Topic Author
22 Feb 2009 10:18
#267120
I'm taking off the points cover housing to do some polishing. I've never done this before, so I was wondering if anyone has any tips. Am I going to mess up the timing, etc if I go any further? I'm such a hack... Here's where I'm at.
  • trianglelaguna
  • trianglelaguna's Avatar
Re: Help with points housing
22 Feb 2009 10:27
#267122
you can take the ignition advace off...but be sure to mark the cam/black round thing under the crank bolt.....as it will go back in the ignition advace either the way it was or if you dont mark it 180 degrees dif....a thirteen mm sockett and the bike in gear on the side stand will free the nut...dont use a 17mm wrench on the inner nut or you will either just turn the crank or like i did ...sheer the crank pin.....the 13 mm end wrench and a small mallet to tap if the sockett wont free it..once you have the ign adv off you can remve the timing housing....lube the ign advace on the two little arms rivets and the groove under the cam/black thingy...before installing....you will be golden from there ...have fun craig(i just did mine friday and it was easy)do you have a shop manual?
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
  • loudhvx
  • loudhvx's Avatar
22 Feb 2009 10:27 - 22 Feb 2009 10:31
#267123
You are going to polish the inside?
If you have the timing plate off as in the photo, you will have to time it from scratch unless you can tell exactly where the timing plate was oriented before you removed it.
If you remove/disassemble the advancer, note the advancer can go back on the hub in two ways. Only one way is correct (to maintain stock configuration). Otherwise it will be "180 out".
Edit: Trianglelaguna beat me to it by a few seconds. :)
Also, if you look very carefully at the advancer arms, you'll notice two little darker pads. They are rubber and rest against the advancer hub. If they are missing, the timing will be altered. Be careful not to damage them with solvent or break them off while cleaning.
Last edit: 22 Feb 2009 10:31 by loudhvx.
  • austin3119
22 Feb 2009 10:39
#267129
Thanks for the help guys. No, I'm not going to polish the inside. :) . Actually, that's the dyna s hanging off of there in the picture.
Thanks again for the help. I really appreciate it. After I mess it up, I'll be back for more help. :)
  • trianglelaguna
22 Feb 2009 10:43
#267132
did you happen to see how the dyna s was sitting on the screws??mine has the same and i used a strobe timing gun and only had to tap the plate a little to re-time it...you be fine
1976 KZ900
2003 ZX12R
2007 FZ1000
  • The Gringo
  • The Gringo's Avatar
  • ¡Usted no necesita otra motocicleta!
22 Feb 2009 10:43
#267133
Be careful polishing on this bike, if you polish it much more you aren't going to have anything left.:laugh: ;)
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
KZ 550 times 2 80 440LTD-Sold
22 Feb 2009 10:49 - 22 Feb 2009 11:04
#267138
Here's the kawasaki.com diagram. :)
[Click on image to enlarge view]
Last edit: 22 Feb 2009 11:04 by Patton.
22 Feb 2009 11:03 - 22 Feb 2009 11:05
#267145
Last edit: 22 Feb 2009 11:05 by Patton.
22 Feb 2009 11:11
#267147
22 Feb 2009 11:27
#267152
22 Feb 2009 11:33
#267155
  • austin3119
22 Feb 2009 17:31 - 22 Feb 2009 19:22
#267266
Damn dude. You got some skills. Wish you lived closer, my bike would be perma parked in your garage. :) I see your posts all over the board, you should open a shop.
Thanks again.
Last edit: 22 Feb 2009 19:22 by austin3119.
