Tire size on stock Z1R wheel?
  • Z1Rider
  • Z1Rider's Avatar Topic Author
18 Feb 2009 19:24
#266044
I just picked up a used GS1100 alum. swing arm for my 78 Z1R. Now that I have a wider/longer arm how much tire can I safely get on the stock 18" Z1R wheel? maybe a 150? Or should I be looking for different wheel?
  • trianglelaguna
  • trianglelaguna's Avatar
Re: Tire size on stock Z1R wheel?
18 Feb 2009 19:27
#266045
here we go again...good luck...oh you'll get answers:laugh:
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
  • gane
  • gane's Avatar
18 Feb 2009 19:28
#266047
Yes. after 130, profile of tire results in less ground patch. G
[img][/img] 1977 KZ1000A1
  • RonKZ650
  • RonKZ650's Avatar
18 Feb 2009 19:41
#266055
I'm relatively sure the Z1R uses a 2.5" wide wheel which was pretty common at the time. You can look at the tire manufacturers data on each tire and they normally specify what size wheel is suited to a certain width tire. 130 would be pushing it as far as practical I would imagine. I do the 120/90 on 2.5" wheels and even that is too wide for the wheel in my opinion and makes crowning of the tire more than desirable.
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
19 Feb 2009 06:43
#266128
How about my situation?
I'm going to be putting an 18" Z1R front wheel on my kz650C2.
Stock Z1R front tire is a 110/90-18 I believe, compared to a 100/90-19 stock kz650 tire.
On the rear I was contimplating going back to 120 width (stock kz650 size) from my current 130 rear, but having a wider front (110) I wondering if I should continue with a 130 rear.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
  • Z1Rider
19 Feb 2009 18:01
#266269
Thanks for the info I got a 130 on it now, it damn near rubs the stock arm. The GS arm will take a much bigger tire but with a 2.5" rim I'm maxed. Does any one know of a similar style KZ rear wheel that might be at least 3"+ wide? Maybe a later model KZ or somthing off a MKII or LTD. I don't want a modern sport bike looking 3 spoke.
  • gane
  • gane's Avatar
19 Feb 2009 18:08
#266271
Z1, Have heard of having stock mags being cut and rewelded to diffrent width/diameters. (am guessing you have mags) spokes are easy, just lace a wider hoop. Luck G
  • Mark Wing
  • Mark Wing's Avatar
19 Feb 2009 19:27
#266302
Check out these guys. www.kosman.net/
Mark
Yorba Linda Cal.
