how big of an offset sprocket....
- kzmarvo
17 Feb 2009 00:28
Whats the bigest offset sprocket that will fit under the sprocket cover on a kz1000?
Watch it folks,i have sticky fingers when it comes to a nice looking set of handle bars:)
- Old Man Rock
Re: how big of an offset sprocket....
17 Feb 2009 04:02 - 17 Feb 2009 04:03
Assuming you're speaking of offset versus number of tooth count in your question....
The cover is not the problem.... Evan at 1/2" (12mm) offset cc sprocket you will need to grind off some of the inner cover....
The problem is chain to frame clearances.... 12mm leaves ~ 3/16th inch clearance if using a 630 O-ring chain.... In converting to a 530 chain/sprocket setup you may buy yourself another 1/16th but not much more than that pending the chain design.....
Do a forum search for cc offset sprockets... Been discussed numerous times...
OMR
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 17 Feb 2009 04:03 by Old Man Rock.
- timebomb33
17 Feb 2009 12:55
3/8" offset will fit under the stock cover
I THINK MY POWERBAND BROKE
- mark1122
- Keep twisting it
17 Feb 2009 14:59
530 and 630 chains are the same width.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- MFolks
17 Feb 2009 15:55
Two websites for custom offset sprockets:
1. www.pmfronline.com
2. www.sprocketspecialists.com
A website to figure gearing ratio's: www.gearingcommander.com
- Old Man Rock
18 Feb 2009 03:17 - 18 Feb 2009 03:22530 and 630 chains are the same width.
Interesting for I was under this same impression but since this discussion has been held so many frigging times where others replied the width is different pending chain manufacturer and which ring setup was in the design....
So, it truly is B.S. then.... :laugh: :laugh: :laugh:
Ah well, all I do know is a 630 with a 12mm(1/2") offset
works without hitting the frame. Tight yes but ~ 1/8th to 3/16" clearance... The chain to tire has plenty of room and I have 180mm on my rear swingarm.
And I did have to grind off the inner cover for the cc sprocket clearance...
Another source of quality sprockets....
americanclassix.com/streetfighter_conversions.html
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 18 Feb 2009 03:22 by Old Man Rock.
- mark1122
- Keep twisting it
18 Feb 2009 07:57
The chain charts that are on line say that the #3 of 630 or 530 represents the width, and that they are indead the same width.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
