180mm 200mm conversion run down.
- kzmarvo
14 Feb 2009 21:06
Alright,so from what i have researched and read this is what i got. Basically to swap the ass end of a kz to a 180mm or 200mm tire bike you do as follows. Get a swingarm,extend it to your liking,get the wheel for that swingarm and a longer chain. Make the swingarm fit the frame, get the wheel spacers milled to make the wheel track straight with the front sprocket. Get a front off set sprocket,maybe stiffin up the frame with some gussets.Get the caliper for the swingarm/wheel you are running,and get the extended brake line. Am i on track folks?
Watch it folks,i have sticky fingers when it comes to a nice looking set of handle bars:)
- supercharged
Re: 180mm 200mm conversion run down.
15 Feb 2009 00:09
sounds good - that is what I'm doing... slow moving at times.
Priority..
- Rear wheel aligned to front- then
- sprockets lined up
May require some custom mods or slight misalignment...
Keep in mind that chain path becomes critical at 180 never mind 200. Chain tends to get REAL close to frame coming off countershaft back to sprocket.
Priority..
Mike D
- 79 KZ1000 LTD Supercharged
- 80 KZ1000 1105cc Pridmore/Vetter tribute
- 79 Honda CBX
- 03 Z1000 Mod
- 80 KZ1000 LTD Modified
- 80 KZ1000 LTD PROJECT on Hold
- 78 KZ1000/900 - Street big block
- 78 KZ1000-NEEDS HELP!
- 80 CBX -Project STARTED
- 81 GPZ1100
- GSRX1200
- 80 CB750F supersport... eahhh not so good
- 1988 KZ1000 Police - 50K miles
- 1978 KZ1000 LTD - should be a quick project
- 2001 KZ1000 Police - 30K miles - chromed Sgt Bike GREAT SHAPE
- 79 Honda CBX
- 03 Z1000 Mod
- 81 GPZ1100
- GSRX1200
- kzr750r1
15 Feb 2009 05:00
Yeah 200 would be a full frame mod. Good luck.
KZ750R1 + 1991 ZR750 = KZR750R1
Better to be shot out of a cannon then squeezed through a tube. - HST
- kzmarvo
15 Feb 2009 12:10
yeah if i get a 180 i'll be happy, just spending my spare time(which is alot)looking on ebay for a deal.I am trying to find the whole deal,swingarm,wheel,complete to buy.
- KruZer
15 Feb 2009 13:54
You can run a 200 tire with a 3inch offset countershaft sprocket and a bearing support plate. The chain will outside the frame....look at some the dragbikes that run 10" wide tires..
Buzz
Buzz
*1977 1000, 1975 KZ998 LSR bike.
- PLUMMEN
15 Feb 2009 15:19
dont forget wider front wheel/tire to go with it.even a good 140-150 rear tire will hold up to more power than a stock chassis can handle on these bikes unless you want to do a lot of modifying of other parts.
