Brake Rotors
  • mazmike
  • mazmike's Avatar Topic Author
Brake Rotors
25 Feb 2006 21:47
#26467
Hello everybody, I'm new here but have loved Kawasaki's for many years,mostly KZ1000's. I need advise. I have a 78 KZ1000 A2A with conversion dual front disc set up. I purchased drilled front and rear rotors from a guy online from a (1980 KZ1000 B4)only to find that the fronts are are thinner by design. Will they work? I see KZ's with duals all the time. Are all the OEM drilled rotors the same? Stock 7mm thick, drilled 5mm. Thanks,Mike
  • steell
  • steell's Avatar
Re: Brake Rotors
25 Feb 2006 23:16
#26474
KZ's with single disk front brakes have thicker rotor than the dual disk models, there is a noticable difference in weight between two of the thick single disk rotors and two of the thiner dual disk rotors.
They do interchange with no problems.
  • wireman
  • wireman's Avatar
  • Visitor
Re: Brake Rotors
26 Feb 2006 03:42
#26488
what steel said:whistle:
