Fork seal replacement...
  • bubba_d
  • bubba_d's Avatar Topic Author
08 Feb 2009 15:30
#263012
Im trying to replace my fork seals on a 77 kz1000. simple right... not so much. i removed the front wheel and drained the fork oil now im trying to remove the tubes by removing the allen screw in the bottom. the screw turns but nothing happens. i can hear the spring on the inside turning but the screw never looses or gains tension. any help would be appreciated. thanks
1977 kz1000.
  • switch
  • switch's Avatar
  • 1981 KZ1000m CSR
Re: Fork seal replacement...
08 Feb 2009 16:28
#263034
bubba,
You need to have a special tool to grab on the doohickey inside, before the allen bolt will be able to turn out. I have 81 kz1000 csr. I don't know if the internal configuration is the same, but I made my own "special tool" with a length of steel bar, a short portion as a t-handle and an 1/2"dia x1 1/4" "A325 hardened bolt" welded to the end. The size of the bolt head is perfect for the "doohickey". Sorry for the terminology but I am operating on my last can of brain juice tonight. Look at the parts diagram on line and you'll see the part I'm talking about.
1981 KZ1000 M1 CSR
2004 Vulcan 1500 Classic (gone)
You do not have to believe everything you think!
  • otakar
  • otakar's Avatar
08 Feb 2009 16:44
#263047
Here is a sample of what needs to be done.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
  • l0g1c
  • l0g1c's Avatar
  • Hanging on for dear life.
08 Feb 2009 16:47
#263051
Hitting it with an impact wrench works too if they're not stuck on too tight. Short bursts. There's a couple good threads here about this.
Another tip. If you haven't pulled your seals out yet, I would highly recommend a seal puller. My local shop lent me theirs and I pulled them out on the spot.
'81 KZ750 LTD
'72 CB350K
Omaha, NE
  • otakar
  • otakar's Avatar
08 Feb 2009 16:50
#263053
Never thought of the impact wrench Idea. That is great! I made my own tool but I will use the Impact wrench next time.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
08 Feb 2009 17:13
#263060
You should do a thorough search of this site...fork seal replacement has been has been extensively covered...I have several KZ1000A1's and have replaced the seals on a number of my bikes...and it can be a bear...the impact wrench works (sometimes)...other times you will have to make a tool to hold the inner fork tubes (sometimes this 'special tool' can be as simple as a broom handle cut at a 45 degree angle to hold the inner tube).
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • arai59
  • arai59's Avatar
08 Feb 2009 17:14 - 08 Feb 2009 17:15
#263061
Ditto........hit it with the impact. Problem solved.
Last edit: 08 Feb 2009 17:15 by arai59.
  • dman3998
  • dman3998's Avatar
08 Feb 2009 17:43 - 08 Feb 2009 17:49
#263068
This is related:
when I had mine off and apart for the major rehab, I had an "accident" when I was buffing the lower aluminum half. I caught on the wheel and catapulted to the floor and put a dent in the seal end of the tube. S#$T! I said about as loud as I could, felt better but it didn't help, it was still bent.
so I turned a piece of steel with a bull nose that fit the id of the other one and pressed it in on a hydrolic press. pushed it right out no problem.
The double end is a my bad the first time made it too small so had to re do it.. story of my life....
Dman
SE Idaho
"Smart only goes just so far, STUPID is UN-limited"
79 KZ1000 LTD
Honda XRL650L
Yamaha RD350B
Yamaha DT400B
Last edit: 08 Feb 2009 17:49 by dman3998.
  • gane
  • gane's Avatar
08 Feb 2009 18:25
#263078
All. in removing the lower allen bolt. loosening & removing are 2 different things.especially w/bikes of our age. tips for those using hand tools. loosen top nut after easing tension off upper triple clamp bolts. (don't remove) before removing fork from bike. drain oil. remove fork/s. now is the time to attempt allen bolt, while spring etc is still providing some friction against valving.it's common for lower valve to want to spin rather than release bolt.sometimes you can load the assembled shock enough to coax it out.if not, building a tool is opt. easier is w/air tools. I usually hit 'em with my 1/2" air impact. if that loosens, but doesn't remove use a high speed 3/8" to remove. this combo works for @ 98% of jobs. If you lack the tools, try showing up at the local shop with a 12 pack and ask if anyone might be intested in removing "these 2 screws". Luck G
[img][/img] 1977 KZ1000A1
08 Feb 2009 18:48
#263085
An impact wrench may help; I used one to spin the allen bolt out without a problem while on the second leg I had to drill off the head as NOTHING would loosen it. However, you still need to make, borrow, steal a special tool to hold the fork cylinder even if you manage to remove the allen bolt using an impact wrench. This is because you need to hold the cylinder during re-assembly so you can tighten the allen bolt to the proper torque. Be sure to consult the FSM for torque level and appropriate locking agent before re-assembly. There are other threads on this site that describe and picture various tools that have been improvised for this purpose. Making one isn't very difficult once you figure out if the top of your fork cylinders have a hex depression or just a round hole. Ed
  • RonKZ650
  • RonKZ650's Avatar
09 Feb 2009 06:59
#263239
Once you get them apart using impact tools, it's easy to see what's needed to make your holder tool. I never bothered and just tighten the allen back up with an impact tool as torque is not critical and it's a large enough bolt where it won't strip using impact tools to tighten. No doubt torqing to spec would be a better way to do it, but not necessary. All I've done, I've only had one that impact tools did not work on, and the allen head rounded off and no way to loosen. I thought I was in a world of trouble, but as luck would have it, there's a nice allen hole in the bolt to center your drill bit on then the instant the head is drilled down to the threads it pops right off and since the bolt is always in oil, the remainder of the bolt will screw right out with your fingers.
  • donthekawguy
  • donthekawguy's Avatar
09 Feb 2009 12:35
#263300
Take a broom stick and cut the end at a 45 degree angle. shove it in the hole to hold the dampner. Use a air wrench on the allen head. It will come right out.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
