Steering Dampers
  • zoro
  • zoro's Avatar Topic Author
Steering Dampers
07 Feb 2009 09:24
#262726
I have a 1980 KZ1000ST,anybody know where a guy might find a period correct plunger type steering damper?
GHOSTRIDER,1980,KZ1000ST
  • trianglelaguna
  • trianglelaguna's Avatar
Re: Steering Dampers
07 Feb 2009 10:03
#262735
i don't know which if any are specific to an 80 1000st...my story is...i wanted one of the black closure looking/plunger? types that were ran on z-1's and h-2's and stuff back in the day.... and kept getting outbid on em...there is one allways on ebay reproduction new for65-85.00.. but iwanted a deal..finaly i bid and won a weathered one for 35 (cleaned and repainted nice)and when i got it i then realized my kz900 will need a mounting tab welded on the frame and a hole drilled in the lower triple tree or a aluminum after market fork tube /damper holder....i bet this will be the case for you too ... as your frame/forks set up is really the same as mine.....you can find em used on e-bay if you look around alot and get one for 15-40 if you wait and don't go crazy....this is all an educated guess and not meant as pure fact...good luck...craig
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
  • zoro
07 Feb 2009 10:32
#262740
Yeah,I can relate verbateum,my bike has a reflecter tab but no triple-tree hole,...yet.I was looking into a fork tube clamp also.I noticed a damper on MKIIs bike that is exactly what Im looking for,and thanks for the quick response!
