1981 csr six fifty ltd brake res
  • wfo3717
  • wfo3717's Avatar Topic Author
03 Feb 2009 15:31
#261993
Trying to help a bud rebuild his bike and he needs the rear brake reservoir and brake line to the caliper. Can't find info on the 81...will an 82 0r 83 work???
  • JMKZHI
  • JMKZHI's Avatar
Re: 1981 csr six fifty ltd brake res
03 Feb 2009 16:44
#262004
The 81-83 KZ650-CSRs came stock w a rear drum brake.
  • wfo3717
03 Feb 2009 17:12
#262009
Maybe it's a 750 ltd, I'll have to check.
  • JMKZHI
  • JMKZHI's Avatar
03 Feb 2009 18:02 - 04 Feb 2009 05:49
#262019
The 1980 650-Ltd also has a rear drum.
If the bike is a 750-Ltd-4, then the 81-83 rear brake parts should interchange. According to the diagrams at Kawasaki.com, the same rear caliper, disk & master cylinder are used on those models as well as the 750-Standard-4s & a couple of other models, depending upon the part.
Last edit: 04 Feb 2009 05:49 by JMKZHI.
