Tube or tubeless rims?
- rstnick
23 Jan 2009 06:37
The rims on my '78 kz650C2 are the tube type, first picture.
Are the '79 kz650C3 rims tubeless? Second pic.
The profile of the outside of the rim is totally different on the C3. More squared off compared to the C2's rounded outter profile.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
- StreetfighterKz
Re: Tube or tubeless rims?
23 Jan 2009 06:55
I know this sounds a little obvious but what's stamped on the rim?
Later, Doug
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
- RonKZ650
23 Jan 2009 06:57
They are tube type. 1979 KZ1000ST and KZ1300 introduced tubeless type tires to the Kawasaki line, then in 1981 other larger bore models went tubeless. It looks like 1983 was the last KZ650 and the only tubeless KZ650 model.
- KawiConvert
23 Jan 2009 07:54
RonKZ650 wrote:
My 78 KZ650 has tubeless rims. The rear rim has TL cast into it and the inner profile has a bead keeper type lip. I doubt that it is off of another bike as it appears nothing else was changed by the previous owners (I'm including oil and spark plugs in this statement
1978 KZ650 D1 ~ Carb jetting: 107.5 & 20 & 4th groove with pods and 4-1 Exhaust
- Jeff.Saunders
23 Jan 2009 08:02
If you know the model the rims come off, you can check the Kawasaki.com parts diagrams to see if tubes are listed for that bike.
- rstnick
23 Jan 2009 09:09
I can't seem to find a casting mark saying either tube or tubeless.
The size cast into the '79 C3 is: J 18 x MT2.15 Dot
Where as the one on my '78 does not have the MT in the size cast, just: J 18 x 2.15 Dot.
It's off a 1979 KZ650C3.
When I check the Kawasaki.com parts diagrams, it shows a tube.
The diagrams also shows the Rim stopper (bead lock) but there are no bead lock posts sticking through the rim like the '78 C2 I have.
This list shows the models that share the Rim stoppers (bead lock):
Model (
KZ1000-A3 (KZ1000) (1979)
KZ1000-A3A (KZ1000) (1979)
KZ1000-A4 (KZ1000) (1980)
KZ1000-D1 (Z1R) (1978)
KZ1000-D3 (Z1R) (1980)
KZ650-C1 (Custom) (1977)
KZ650-C2 (Custom) (1978)
KZ650-C3 (Custom) (1979)
Guess I should remove the tire and check for the "bead keeper type lip".
I just thought that with the completely different shape to the rim, and having no bead locks, that it was a tubeless type of rim.
Model (
Rob
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
- RonKZ650
23 Jan 2009 10:02
Well I know for sure a 78 KZ650D is a tube type wheel. At least they fitted a tube from the factory.
- KawiConvert
23 Jan 2009 10:16
RonKZ650 wrote:
I've got the same year and model and it has tubeless wheels. It probably came with tubes from the factory, but it is a tubeless wheel. Just my 0.02
- rstnick
23 Jan 2009 11:18The rear rim has TL cast into it
KawiConvert, where did you find the TL cast mark on the rim?
I looked all over it and could not find any Ts, TL or any other marks other than the size mark casts and Kawasaki and Enkel I believe.
Rob
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
- H2RICK
- Is this a fun bike, or what!!!
23 Jan 2009 12:06
My 650C2 came stock with the rim locks and tubes. My wheels have a profile like pic #1. Don't know whether there are any "TL" marks in the casting or not.
KZ650C2 Stock/mint. Goes by "Ace".
H2A Built from a genuine basket case. Yes,it's a hot rod.
GT550A Stock/mint. Pleasant stroker.
2006 Bandit 1200S for easy LD rapid transit
Various H2 projects in the wings.
- KawiConvert
23 Jan 2009 12:23
rstnick wrote:
On the drive side of the rim it has
"T 16 x 3.00TL DOT"
cast in it. I assume the TL means tubeless as it has the keeper lip. Mine also had Kawasaki and Made in Japan cast on it.
"T 16 x 3.00TL DOT"
- steell
23 Jan 2009 16:23
rstnick, the second rim pictured is also a tube type rim. See the squared off center section? Notice that it is really shallow? Tubeless rims have a deeper (much deeper) well in the center of the rim for the tire bead to slide into during installation/removal.
