82 spectre 1100 to 750 rear air shocks
- ep99
18 Jan 2009 22:41
got this bike last week!! am wondering is the Spectre 750 rear shocks will fit my 1100? found mine coulden't hold air pressure !! please advise, and thanks
- Killbert
- Riding Vintage
Re: 82 spectre 1100 to 750 rear air shocks
20 Jan 2009 12:39
That's a good question, and I'm curious too. Check your PM!
1982 Kawasaki KZ1100 Spectre D1
Looking for a sissy bar/back rest/luggage rack! PM ME!
- KawiConvert
20 Jan 2009 12:51
Depends on the bushing for the shock mount. I have Yamaha shocks on my 650 that fit for length and bolt size. I just had to switch out some of the bottom bushing/spacers.
1978 KZ650 D1 ~ Carb jetting: 107.5 & 20 & 4th groove with pods and 4-1 Exhaust
- ep99
27 Jan 2009 22:48
I just received today and couldn't replace!!due to the spacer/bushings are just very tiny difference; 750 is larger then 1100's also 750 is Showa shocks, KYB for 1100, and I might be able to fit them in w/out switch all or part of bushings by remove the old shocks and have helper sits on the bike to lower and replace them!! or any sugession? thanks
- ep99
30 Jan 2009 10:42 - 30 Jan 2009 10:47
yes, confirmed Spectre750 shocks can be switched to 1100!!
got that done last night in 30 mins, took both of old one off, let the rear wheel freely up and down and mount the 750 shocks on (Showa shocks not KYB)by align the eyelets, wroking on one side then another.
Last edit: 30 Jan 2009 10:47 by ep99.
- timebomb33
01 Feb 2009 00:33
does the bike ride any different then before the 1100 shocks packed it in
I THINK MY POWERBAND BROKE
- okie1
01 Feb 2009 07:41
Seems i have a set of Spectre shocks on my 81 Kz1000 and they look factory. I have not rode the bike yet but will very soon. I will let you know when i do.
1981 KZ 1000
1979 KZ 1000
1979 KZ 1000
- ep99
02 Feb 2009 15:52
since they are the same lengh as well as the stifness dial adjustment,I haven't notice any diffenence.
- wiredgeorge
03 Feb 2009 06:19 - 03 Feb 2009 06:21
The spring rates in the shocks will likely be a bit different. I don't much care for air shocks. Everybody loves the idea of riding on air as it conjures up visions of a cushy ride but in real life, air doesn't dampen well as it doesn't have much compression. In other words, if you bump the air pressure up some, the bike will ride harshly. I have had air shocks on a number of bikes and this always seems to be the case. I prefer oil dampened shocks with fairly high spring rates. About the best I have used are Progressive 440s. Progressive 12s work well on a KZ. Last, if you are a bike nut, contact Progressive customer support and buy a bag of bushings that will allow you to adapt most any eye-to-eye shock to your KZ... They include a bushing kit with most all the shocks they sell and you can buy this kit separately and it is a lot easier than trying to fab your own bushings as many are very thin and trying to sand plastic or even metal is tough to get them to fit; easier to use the correct sized bushing.
Last edit: 03 Feb 2009 06:21 by wiredgeorge.
