Is anti-dive required?
- LukeJ
18 Jan 2009 17:34
Hi guys, I have just fitted a HEL stainless steel brake system onto the front of my GPZ750 A1 1983 model.
Would these new lines bypass the anti-dive system and just go straight onto the caliper?
If so, will no anti-dive mechanism affect the handling of the bike in any way?
Many thanks in advance
Luke
Luke
- CoreyClough
- GPz550 Addiction
Re: Is anti-dive required?
18 Jan 2009 17:52
On
www.GPz550.com
One member has bypassed the anti-dive system with great success here:
www.nwsca.com/scripts/gpz_forum_2005/topic.asp?TOPIC_ID=4364
I have the parts, but haven't tride it yet. They are on my list of things to do on my GPz550.
'85 GPz550(ZX550-A2)
- PLUMMEN
18 Jan 2009 17:58
i bypassed the anti dive on my 82 gs1100e suzuki back in the early 90s and was amazed at the differance in braking power!
- dutchz
18 Jan 2009 18:06
There's a drawing of a block off plate here:
www.kawasakimotorcycle.org/forum/vintage...anti-dive-forks.html
1974 Kawasaki Z1
Stock front hub and rear axle.
- LukeJ
18 Jan 2009 19:38
Thanks very much guys, I will investigate it further on my end.
- timebomb33
19 Jan 2009 20:16
yes get rid of it if you haven't noticed the oem's havent used that overcomplicated system for years. so it never worked all that well to begin with.
I THINK MY POWERBAND BROKE
- Lorcan
- Speed Loony
25 Jan 2009 01:08
If you can't be bothered to make block-off plates just remove the tops of the anti-dive units, you can then use regular brake hoses straight to the calipers.
A set of progressive fork springs, with spacers, help too and mean you can forget about pumping the forks up with air to stop them bottoming out.
760cc - 8.69@162mph
810cc, 211mph www.750turbo.com
www.stormdragbike.com
- LukeJ
25 Jan 2009 04:24
Yeah I am trying to get the block off plates made by a local CNC company here - should be done this week I hope.
It'd be nice if we could get the file at a bigger res or at least clear to read the measurements.
- PLUMMEN
25 Jan 2009 09:13
all idid on the suzuki was remove the extra hoses and use shorter banjo bolts
- Lorcan
- Speed Loony
25 Jan 2009 23:42
Bigger drawing here
www.750turbo.com/forum/viewtopic.php?t=7826
760cc - 8.69@162mph
- CoreyClough
- GPz550 Addiction
26 Jan 2009 04:56
How does that plate look mounted on the forks?
- Lorcan
- Speed Loony
28 Jan 2009 02:20
Like this
www.750turbo.com/lorc98.jpg
760cc - 8.69@162mph
