630 to 530 chain coversion on 95 kz1000p
  • Koehnm1
  • Koehnm1's Avatar Topic Author
16 Jan 2009 07:02
#258217
Anybody have any luck with this, also I am wanting to change gear ratio from 2.73 to maybe 2.33 or 2.25 want lower rpms at highway speed. Not sure what gears to go with on 530 set-up as everything I have found to calculate is for 630 chain.
  • Old Man Rock
  • Old Man Rock's Avatar
Re: 630 to 530 chain coversion on 95 kz1000p
16 Jan 2009 09:16
#258230
630 to 530/520 conversion formula as follows...
Counter sprocket:
15/5 x 6 = 18 tooth 530.
Rear sprocket:
35/5 x 6 = 42 tooth 530.
OEM 630 Gears:
35/15 = 2.33 gear ratio
530 Gears:
42/18 = 2.33 gear ratio
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • PLUMMEN
  • PLUMMEN's Avatar
16 Jan 2009 10:07
#258245
put a taller profile rear tire on there.;)
