Rear wheel swap.
  • PunkRawkKid
  • PunkRawkKid's Avatar Topic Author
Rear wheel swap.
13 Jan 2009 09:42
#257660
I need your help....I blew out my rear wheel twice in four days on my 1978 kz650b model.the tire is fine but the tube has blown(got a new one and it blew again).and from what I've seen new spoke sets aren't cheap.I think it may be a spoke popping the tube....the spokes are original as far as I know...
But anyways...swapping out the rear wheel will be cheaper than new spokes and I want to go to a mag wheel anyways...what can I get to use with my stock swingarm and stock axle?I'd like a radial rear if possible.
I need to get this done by tomorrow night so time is of the essence.thanks!
Re: Rear wheel swap.
13 Jan 2009 12:53
#257672
Where spoke is protruding into wheel area and damaging tube, may grind down any excessive protrusion, and then use a layer or two of duck tape around the wheel inside the rim or go first class with a rubber rim strip (if not already using).
Good Luck! :)
