Front fender bolts
  • oldkaws4ever
  • oldkaws4ever's Avatar Topic Author
  • Have no regrets...... You only live once.
Front fender bolts
05 Jan 2009 22:34
#256379
Ok i don't know how i did it but i have lost the the 4 bolts that hold my front fender on my Z1. Does anybody know were i can buy a set of them? Maby Z1 has them? Or anybody have a set layin around? Thanks, Jim.
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
  • KawiConvert
  • KawiConvert's Avatar
Re: Front fender bolts
05 Jan 2009 23:58 - 06 Jan 2009 00:01
#256382
I'd check the local hardware store. Our Ace store has a whole row of bolts, nuts, etc. Including some chromed acorn style nuts that are metric. I believe they are 6mm coarse (I think that means a 6mm x 1mm threads but don't quote me).
Or Mcmaster has something close for about 1.88 each. Again, you'll need to verify the thread size and pitch, but I found this item 91982A250 on McMaster.com and it looks close.
1978 KZ650 D1 ~ Carb jetting: 107.5 & 20 & 4th groove with pods and 4-1 Exhaust
Last edit: 06 Jan 2009 00:01 by KawiConvert.
  • RonKZ650
  • RonKZ650's Avatar
06 Jan 2009 07:05
#256415
It's a 8mm bolt 16mm long if that helps. Should be at a decent hardware store.
  • MFolks
  • MFolks's Avatar
06 Jan 2009 10:53
#256437
Some of the Ace hardware stores carry metric SS, put a little anti-seize on the bolts for corrosion protection and easy removal in the future.
  • BSKZ650
  • BSKZ650's Avatar
06 Jan 2009 10:57
#256438
I thought the heads were "shorter" that a standard bolt, clearance issue,,, I may be wrong, though
77 ltd1000, current rider
76 kz900, just waiting
  • RonKZ650
  • RonKZ650's Avatar
06 Jan 2009 11:35
#256439
They change part # at least once. Same bolt used to hold the horn to the frame on KZ650s,900,1000, grab rail bolt on a KZ650, bottom headlight bolt on a KZ650SR ect. Standard bolt. The changed the name from a "hex bolt" to an "upset bolt" whatever that may mean. I guess upset bolt means you're "upset" when it's lost :)
  • oldkaws4ever
06 Jan 2009 15:11
#256458
Thanks guy's i will stop off at ACE, ang grab them. And yes im upset because i lost them.....lol
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
  • arai59
  • arai59's Avatar
06 Jan 2009 15:19 - 06 Jan 2009 15:20
#256460
Should be a 8x1.25 thread and I guess it's 16mm long. Most stores carry even lengths like 15 or 20 mm.
Last edit: 06 Jan 2009 15:20 by arai59.
  • GregZ
  • GregZ's Avatar
06 Jan 2009 16:35 - 06 Jan 2009 16:36
#256466
fender bolts 8x16
Why don't you just go to your local kawasaki dealer
part number 110B0816
they can order them or will have something simalar
You will be suprised what is still available at the
Kwack shop.All those n.o.s. parts on fleabay are
available at a fraction of the cost at your local
dealer
cheers
Last edit: 06 Jan 2009 16:36 by GregZ.
  • oldkaws4ever
06 Jan 2009 16:47
#256467
thank's Greg, i guess the kawi dealer is on my list of places to go tommorow.
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
