Fork ID
- Muddy
Fork ID
05 Jan 2009 16:28
Is there an easy way to tell the different model kz forks? Specifically the difference between forks with the caliper in front and forks with it in back. I bought a set of forks from a breaker. He told me they were from a kz650 with the breaks behind the leg. But I bought a set of calipers froma member for that model and there's just no way they would work. Which makes me think they are the other style fork. Any ideas?
- Kawickrice
Re: Fork ID
05 Jan 2009 16:52
Got any pics?
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
- Mcdroid
- Gone Kwackers
Re: Fork ID
06 Jan 2009 02:33 - 06 Jan 2009 02:36
Muddy wrote:
Kawasaki went from leading brakes to trailing brakes in 1978...the lower fork units are the same on early KZ650/1000...the differences are in the tube length and spring length...however, I am running '78 KZ1000 lowers on my 1977 KZ1000A and have retained the leading brakes simply by reversing the fork legs...but pictures sure would help:)
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Last edit: 06 Jan 2009 02:36 by Mcdroid.
Re: Fork ID
06 Jan 2009 10:50
Actually, the 1977 KZ650C1 had dual trailing front brakes.
- Mcdroid
- Gone Kwackers
Re: Fork ID
06 Jan 2009 11:42
650ed wrote:
You are absolutely correct...I was thinking of the B model:blush:
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- OnkelB
Re: Fork ID
06 Jan 2009 12:07 - 06 Jan 2009 12:08
Muddy wrote:
Yes, the forks for calipers in front will have the mount for the fender support on the opposite side of the caliper mounts, the forks for calipers behind will have the mount for the fender support on the same side as the caliper mounts. The CSR (H) models use a short fender with no support and no support mount, these forks are easily identified by the leading axle.
The 650 SR (D) models have dual calipers behind the fork legs but they also use smaller rotors than the other 650 models, so the mounts for the calipers sit closer to the axle - you might have gotten a set of SR forks, there's some more info and pics here and here.
I bought a set of forks from a breaker. He told me they were from a kz650 with the breaks behind the leg. But I bought a set of calipers from a member for that model and there's just no way they would work. Which makes me think they are the other style fork. Any ideas?
77 KZ 650 B1, 82 GPz 1100 B2.
Last edit: 06 Jan 2009 12:08 by OnkelB.
- Zedone
Re: Fork ID
06 Jan 2009 18:14
The top of the fork legs (@ the tree) are flush with the top of the leg and use a flat rubber cover on the 78 & up . The older models use a solid aluminum threaded bolt (hex head) 17mm or 19mm head size on the Z1's & KZ1000's.... (if memory serves) I would assume the KZ650's are the same way... different fork leg dia. possibly smaller.
1977 KZ1000A1
1977 KZ1000A1 (Superbike Project)
1969 Chevrolet C/10 Short Fleet
