Swingarm ?
- badrhino
Swingarm ?
04 Jan 2009 19:16
Will the older ZX-6 swingarms fit the KZ1000 without too much hassle?
I have one fron the early 90's and one from the later 90's early 2000's.
1980 KZ1000 with a 1982 KZ1000J motor with 1100 pistons and heads, Vance & Hines, 29MM Smooth Bores, Work in Progress
Franken Z!
Franken Z!
- donthekawguy
Re: Swingarm ?
04 Jan 2009 23:32
If it's wider at the pivot just grind it or have it machined down. If it's not wide enough you can use washers as spacers. You will either need to buy shock mounts from Jeff or convert it to mono shock. But it will work.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
- StreetfighterKz
Re: Swingarm ?
05 Jan 2009 06:25
I think that the ZX6D/E models fit without too much hassle but F,J, and newer arms might be too wide to fit without machining.
Later, Doug
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
- badrhino
Re: Swingarm ?
05 Jan 2009 17:11
donthekawguy, nice avatar!
Thanks guys!
Thanks guys!
Franken Z!
Franken Z!
