wide 630 chain
- Captaingamez
wide 630 chain
04 Jan 2009 12:44
i ordered a 630 chain off feebay and got a good price on it. but its about 1/16th to 1/8 wider on the rollers than the stock one. can i still run it? will it hurt anything?
1979 Kz1000 MKII road racer project
1994 Seca II, pile in the corner
1973 Honda cb175 cafe racer
1971 Yamaha AT1
1975 Massey Fergusson MF440
1971 Skiroule 300rr
1971 Yamaha AT1
1971 Skiroule 300rr
- dutchz
Re: wide 630 chain
04 Jan 2009 13:05
Stock one a non O-ring and the new one an O-ring chain maybe? I had an O-ring 630 on mine with no clearance issues. I'm sure some others will chime in.
1974 Kawasaki Z1
Stock front hub and rear axle.
- Old Man Rock
Re: wide 630 chain
04 Jan 2009 17:02
First, please update your profile for which bike your speaking of or mention in your questions...
Since 630 chain most probably 900-1000...
O-ring 92 link chain is the norm, should be no problems....
Of course we have to assume your bike is OEM swing-arm, counter and rear sprockets.
OMR
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- PLUMMEN
Re: wide 630 chain
04 Jan 2009 18:13 - 05 Jan 2009 15:49
Last edit: 05 Jan 2009 15:49 by PLUMMEN.
- Old Man Rock
Re: wide 630 chain
04 Jan 2009 18:17make sure you buy new sprockets to go with it!
530 or 630.... :laugh: :laugh: :laugh: :laugh: :laugh: :laugh: :laugh: :laugh: :laugh: :laugh: :laugh: :laugh:
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- PLUMMEN
Re: wide 630 chain
04 Jan 2009 19:28 - 05 Jan 2009 15:50
Last edit: 05 Jan 2009 15:50 by PLUMMEN.
- z1kzonly
Re: wide 630 chain
04 Jan 2009 19:50
First, is it Diamond, 60 size industial chain??? With split collars? I tried it once in 1979, thaught I scored a freebie from work. Till a hole shot cracked my sprocket cover and bent the push rod for the clutch. Luckily I was on my own street.
Or is it heavy duty, high perf. chain?
Tsubuki, RK, EK, SK, U-ok? I'm ok?
- Captaingamez
Re: wide 630 chain
05 Jan 2009 04:34
im not sure the manufacturer it doesnt say on the box. but i have stock gearing. the roller width is as i said about 1/16th to 1/8 wider than the original, and the sprocket. idk if it will walk back and fourth while riding or if it will be ok to have a bit of space.
1971 Yamaha AT1
1971 Skiroule 300rr
1971 Yamaha AT1
1971 Skiroule 300rr
- Captaingamez
Re: wide 630 chain
21 Mar 2009 19:40
Any new ideas on this? really could use the info. i have been runing the chain a bit, but i havent gotten in on the highway for a long ride. the chain works and everything, its an 0-ring chain. but if you grab the chain you can slide it back and fourth on the sprocket a little less than an 8th inch. the chain is for a motorcycle. but i dont have a manufacturer on it.
1971 Yamaha AT1
1971 Skiroule 300rr
1971 Yamaha AT1
1971 Skiroule 300rr
- T_Dub
Re: wide 630 chain
21 Mar 2009 20:08
It shouldn't go anywhere, although it might wear quicker. If I were you I'd convert the whole setup to a modern 530 o-ring chain.
1977 KZ650B1
-810cc
-Cavanaugh Racing Head
-Mikuni RS34's
-GPR Muffler
-810cc
-Mikuni RS34's
-GPR Muffler
Re: wide 630 chain
21 Mar 2009 20:52
Look on the links. They should each be marked with the brand. Ed
- Captaingamez
Re: wide 630 chain
21 Mar 2009 21:03
Alright, ill just keep an eye on the wear a little more.
this chain does not have a labeled manufacturer.
thanks
thanks
1971 Yamaha AT1
1971 Skiroule 300rr
1971 Yamaha AT1
1971 Skiroule 300rr
