Fork tube caps
  • ssalyer
  • ssalyer's Avatar Topic Author
Fork tube caps
30 Dec 2008 10:00
#255369
I'm looking for a set of fork tube caps for my 1978 1000. I currently have some kind of air system [ inactive] that requires a large brass nut on top of the fork tube. I want to go back to the original setup. They are the ones that thread down in the tubes flush with the top [see pic]. If anyone has a pair they are interested in selling please let me know.
1978 KZ1000 A2A
  • wiredgeorge
  • wiredgeorge's Avatar
Re: Fork tube caps
30 Dec 2008 13:00
#255395
A couple years back, I bought some off ebay. They are essentialy black rubber domes that have a square rubber bit that fits into the 1/2" square hole. I am not sure if they were OEM parts or not. I suspect they were. If you can find an OEM part number for this type cover, you could likely do a google search and find a pair. Failing to find any, I suspect I could fab some fairly easily out of aluminum or even wood.
  • ssalyer
Re: Fork tube caps
30 Dec 2008 13:55
#255407
Thanks WG, It is actually the threaded nut shown in the picture that I need. I just posted that pic I got from redline's site as an example of the model. I did find them new but there about $40 each. so I was hoping to find a couple used ones. Oh yeah, thanks for the amazing job on the carbs this past spring. The bike has never run better.Scott
1978 KZ1000 A2A
Re: Fork tube caps
30 Dec 2008 13:58
#255408
ssalyer wrote:
I'm looking for a set of fork tube caps for my 1978 1000...original setup...thread down in the tubes flush with the top [see pic]. If anyone has a pair they are interested in selling please let me know.
According to kawasaki.com - - -
The metal threaded fork tube cap with the square hole is Part# 44029-1003 used on the following models:
KZ1000-A1 (KZ1000) (1977)
KZ1000-A2 (KZ1000) (1978)
KZ1000-A2A (KZ1000) (1978)
KZ1000-A3 (KZ1000) (1979)
KZ1000-A3A (KZ1000) (1979)
KZ1000-A4 (KZ1000) (1980)
KZ1000-B3 (KZ1000 LTD) (1979)
KZ1000-B4 (LTD) (1980)
KZ1000-D1 (Z1R) (1978)
KZ1000-D3 (Z1R) (1980)
KZ1000-G1 (Classic) (1980)
KZ650-F1 (1980)
KZ750-B1 (1976)
KZ750-B2 (1977)
KZ750-B3 (1978)
KZ750-B4 (1979)
KZ750-G1 (LTD II) (1980)
The domed rubber cover that plugs into the square hole is Part# 11012-1017 used on the following models:
KZ550-F1 (Spectre) (1983)
KZ550-F2 (LTD Shaft) (1984)
KZ550-M1 (LTD Shaft) (1983)
KZ650-B1 (1977)
KZ650-B2 (1978)
KZ650-B2A (1978)
KZ650-B3 (1979)
KZ650-C1 (Custom) (1977)
KZ650-C2 (Custom) (1978)
KZ650-C3 (Custom) (1979)
KZ650-D1 (SR) (1978)
KZ650-D1A (SR) (1978)
KZ650-D2 (SR) (1979)
KZ650-E1 (LTD) (1980)
KZ650-F1 (1980)
KZ750-B1 (1976)
KZ750-B2 (1977)
KZ750-B3 (1978)
KZ750-B4 (1979)
Good Luck! :)
  • bountyhunter
  • bountyhunter's Avatar
Re: Fork tube caps
30 Dec 2008 15:33 - 30 Dec 2008 15:35
#255425
salvage yards should have them.
www.ricepaddymotorcycles.com
www.tricountymotorcycles.com
www.usedmotorcycleparts.net
www.caldwellmotortoys.com
www.MOTOLANE.COM
www.stevescyclesalvage.com
www.MrCycleParts.com
Last edit: 30 Dec 2008 15:35 by bountyhunter.
  • ssalyer
Re: Fork tube caps
30 Dec 2008 17:49
#255443
Thanks for all the tips guys. Scott
1978 KZ1000 A2A
