drilling handlebar control switch hole
- GregZ
29 Dec 2008 18:37
On stock Z1 handlebars,how far from the end do you drill the hole for the control switch from spinning??
So if someone has a z1 handle bar lying around can you please measure for me
thanks
thanks
- arai59
Re: drilling handlebar control switch hole
29 Dec 2008 18:54
Never actually measured one but I always drill the hole on the throttle tube side ....leaving about 1/8" end play for the grip. Just line up and check your topside preferred level.
- image
29 Dec 2008 19:15
as i like to experiment with different bars and positions, i went the easier option of removing the locating tab.
- trianglelaguna
29 Dec 2008 20:44
me too it's the first thing i remove..and i tighten really good after....the only thing that can rotate it is a strong wrist or a crash ..in which case all of my handle bar stuff is loose enough to rotate before snapping...not the answer i know...but confer with IMAGE....
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
2003 ZX12R
2007 FZ1000
