Brake Rotor Identification
  • kenskz1000
  • kenskz1000's Avatar Topic Author
28 Dec 2008 10:38
#255094
Hi all, I have two brake rotors one marked 2N and other marked 2F, does anyone know what bikes these are from? I am looking for a KZ1000A rear brake rotor and not sure if it is either one of these. Any help would be great. Thankyou in advance, and happy new year to all.
  • PLUMMEN
  • PLUMMEN's Avatar
Re: Brake Rotor Identification
28 Dec 2008 11:15
#255099
got a picture?the center hub of the rotor should look same as front rotor but not as much offset built into it.;)
  • Jeff.Saunders
  • Jeff.Saunders's Avatar
  • Vendor
  • Vendor
28 Dec 2008 13:39
#255115
The 2 in the first position says it's made in 1977. The F would be from May/June and could have been on a very late 77 or early 78 bike. The N probably November/December of 1977 and it would be a 1978 model.
  • kenskz1000
28 Dec 2008 13:52
#255116
Jeff, can you tell if either is for rear?
  • kenskz1000
28 Dec 2008 14:16
#255119
Is this 1977 KZ1000 front or rear?
  • Jeff.Saunders
  • Vendor
  • Vendor
28 Dec 2008 15:27
#255132
It looks like a front one - is it 7mm thick (wear limit 6mm)?
  • franknsr
  • franknsr's Avatar
28 Dec 2008 19:37
#255158
It scares me that you guys know this much about these bikes. I think I like it here. :-)
Formerly CSRchopper
1991 KZ1000P
Gone but not forgotten
1986 ZG1000
1982 650 CSR -shoulda kept this one-
Lisle Illinois, USA
  • donthekawguy
  • donthekawguy's Avatar
28 Dec 2008 23:36
#255201
The rear on the ltd is smaller than the a model by about 1/4 inch or so if I remember right. Are you using cast or spoked wheels?
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
  • kenskz1000
29 Dec 2008 01:04
#255209
I am using mag wheels, the bike is a 1977 KZ1000 LTD and my rear brake caliper seized so I am using a A model caliper. And you are right my LTD rotor is too small. Looks like I won this rotor last night on e-bay. Hope it fits.
29 Dec 2008 01:25
#255210
kenskz1000 wrote:
...1977 KZ1000 LTD and my rear brake caliper seized....
Is rear brake caliper beyond hope of restoration? :unsure:
Unless destroyed, may be possible to unseize.
Good Luck! :)
  • kenskz1000
29 Dec 2008 01:54
#255212
It is unseized but piston was garbage and my A caliper is already powder coated and ready to go. I had it on the bike and sure enough the brake pads did not line up with ltd rotor. Its hard to tell by this picture but the rotor turned brown after seizing and limping home. Also a picture when built.
