new problem
- donthekawguy
new problem
25 Dec 2008 05:00
I was looking around tonight for a new rear sprocket and all I could find was 40-41 and 42 tooth. With my 15 tooth front that would be crazy rpm's on the highway. BTW I'm using a gs 1100 spoke rear wheel with my gs arm. It's looking like I will need a custom rear sprocket. Anyone have any recommendation? I will probably do a ton of highway/freeway riding this upcoming summer and want the rpm's low. I'm thinking maybe a 15/31 set up or maybe even 16/32 (liberal speed limits in Montana). :woohoo:
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
Re: new problem
25 Dec 2008 08:49 - 25 Dec 2008 08:53
donthekawguy wrote:
But on the bright side, the s-l-u-g-g-i-s-h new acceleration won't cause anymore soiled undies (unless trying to hurriedly pass a semi without a couple of downshifts). :laugh:
Good Luck!
and all I could find was distressing info about how a lower more relaxed rpm highway cruising speed wouldn't increase highest attainable top speed, but might well lower it, and definitely take a lot more time getting there.I was looking around tonight for a new avatar....
Good Luck!
Last edit: 25 Dec 2008 08:53 by Patton.
- trianglelaguna
Re: new problem
25 Dec 2008 11:24
no,no,,he must have sat in some coffee....
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
2003 ZX12R
2007 FZ1000
- StreetfighterKz
Re: new problem
25 Dec 2008 18:59
donthekawguy wrote:
What size pitch do you need? I can see what I can find. Also if you have to can you go with a 17t front if available?
Later, Doug
I was looking around tonight for a new rear sprocket and all I could find was 40-41 and 42 tooth. I'm thinking maybe a 15/31 set up or maybe even 16/32 (liberal speed limits in Montana). :woohoo:
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
- donthekawguy
Re: new problem
25 Dec 2008 23:06
StreetfighterKz wrote:
I'm going with 630. Won't I have to grind some clearance with a 17 tooth?donthekawguy wrote:I was looking around tonight for a new rear sprocket and all I could find was 40-41 and 42 tooth. I'm thinking maybe a 15/31 set up or maybe even 16/32 (liberal speed limits in Montana). :woohoo:
Later, Doug
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
- WABBMW
- Let The Good Times Roll !
Re: new problem
26 Dec 2008 21:06
donthekawguy:
I bought a rear sprocket from Rebel Gears. www.rebelgears.com
My 650 originally had a 13 / 33 gearing with 630 chain. I changed the rear to 26, keeping the 13 up front. The 2:1 ratio works well on the highway. The 650 starts to load up a little above 85 MPH or perhaps 75 if there is a strong headwind. With a 130/90-16 tire, it runs about 79 MPH at 5,000 RPM.
With its greater torque, your 1000 should have no trouble at all. Good luck.
Bill Baker
Houston, Texas
1982 KZ650 CSR
2008 Yamaha FZ1
2006 Yamaha FZ1
1977 Honda Supersport 750 four (sold)
1984 Honda Nighthawk 650 (sold)
Houston, Texas
1982 KZ650 CSR
2008 Yamaha FZ1
2006 Yamaha FZ1
Re: new problem
27 Dec 2008 05:53
Might enjoy not searching for an imaginary 6th gear.
But don't go for pinks.
Good Luck!
Good Luck!
- trianglelaguna
Re: new problem
27 Dec 2008 06:34
hey that is the truth...my girl knows nothing about bikes and she sometimes asks me after a ride what i was doing shifting again on the freeway.....Patton wrote:
Good Luck!
1976 KZ900
2003 ZX12R
2007 FZ1000
2003 ZX12R
2007 FZ1000
