Adjusting shocks
- OKC_Kent
Adjusting shocks
21 Feb 2006 05:57
Is there an easy way to adjust the stock shocks if you don't have the shock tool?
Cashion, OK
78 KZ650 B2 85,000+ miles
- ejshotgun
Re: Adjusting shocks
21 Feb 2006 06:11
I used a piece of leather between the jaws of a pair of channel locks and the shock. No scratches and worked just fine.
- OKC_Kent
21 Feb 2006 08:39
Thanks ej, i was thinking along that line, but thought i'd ask first.
Cashion, OK
- steell
21 Feb 2006 11:12
I sometimes grab hold of the adjusting collar and lift and rotate it by hand.
Not the easiest thing to do though
- giftofthegods77
21 Feb 2006 11:38
I used a shop rag and a pair of vise grips. Leather sounds like a better idea, but the rag works well too. In the end, it was much easier than using the shock tool.
- BARNEYHYPHEN
21 Feb 2006 13:27
You might find it very much easier if you get the back wheel up off the ground first.
- Duck
- e vica na i sau na ga
21 Feb 2006 15:41
A set of spanners is good to have in the tool box. Needed to adjust head bearing play on may bikes and they are not expensive tools.
-Duck
-Duck
- OKC_Kent
22 Feb 2006 11:39
Cheap is good Duck! I keep bidding on these $5-10 shock tools on ebay that look just right for both shocks and neck nuts, but get beat every time:lol:
Cashion, OK
