Sprocket Sizing and Speed
  • Facility Guru
  • Facility Guru's Avatar Topic Author
  • I love restoring bikes!
08 Dec 2008 17:17
#251500
I have a question that I'm sure you guys can help a newbie with!
I was told that I can 'drop-a-tooth' on my front chain sprocket to gain some higher end speed.
Right now I top-out at 70 with around 6000 RPMs.
Where would I be able to find such a bike-specific part?
AND how hard is this to do?
Thanks for all the help so far!
ROB
1992 KZ-1000 P-11
Running Good, but better is always great!
  • MFolks
  • MFolks's Avatar
Re: Sprocket Sizing and Speed
08 Dec 2008 18:20
#251510
Go to the website www.gearingcommander.com It covers chain speed and sprocket ratio's
  • timebomb33
  • timebomb33's Avatar
08 Dec 2008 18:37 - 08 Dec 2008 18:39
#251513
you want more top end, smaller sprocket on the back what do you have for a gear combo on there now it sounds like you have hillclimber gearing on there now.go bigger on the front 3 theeth on the back is equal to 1 on the front.
I THINK MY POWERBAND BROKE
Last edit: 08 Dec 2008 18:39 by timebomb33. Reason: added something
08 Dec 2008 19:35
#251522
You state that you "top out at 70 with around 6000 RPMs." Are you saying that your bike won't pull more than 6000 RPMs in high gear? If that's the case, you may have other problems that gearing will not improve. Ed
  • donthekawguy
  • donthekawguy's Avatar
08 Dec 2008 23:22
#251554
Get a smaller back sprocket and check your front to make sure it's a 15 tooth. Someone has put different sprockets on for quicker take off response. Go with a 15 tooth up front and a 32 tooth in the rear. That will help.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
