Brake Caliper Piston is FROZEN!! How do I remove?
- Alabaster
- Dallas, TX
01 Dec 2008 16:03
I've tried the 'ol blow air into the inlet to no avail. It is a two piston caliper so I'm trying to get them out together. I've soaked them in penetrating oil, used extra fine sand paper on the exposed part of the piston then sunk it with a c-clamp. I really don't want to convert to a single piston caliper so if anyone knows of a way I'm not trying then please let me know. I know there is a kit I can order for mucho $$$$$$$$$$!!! Thanks in advance.
'07 Ducati SC1000S
'79 KZ1000
'79 KZ1000
- StreetfighterKz
Re: Brake Caliper Piston is FROZEN!! How do I remove?
01 Dec 2008 16:52
I just read something about a method a guy used to push out his stuck caliper piston. I just browsed the article but he used a grease gun to force the piston out. Something was said about the grease was thicker and he could get more pressure from the gun? Like I said I only glanced at the article but maybe you can get an idea from it.
Later, Doug
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
- Alabaster
- Dallas, TX
01 Dec 2008 17:26
Thanks bro. That's a good thought. Although, the thought of cleaning out thick grease is enough to make me think twice. I have an extra master cylinder from a car and I'm thinking of rigging the caliper to the MC and stomping on the plunger. What if I used a torch to heat up the pistons?
'07 Ducati SC1000S
'79 KZ1000
'79 KZ1000
01 Dec 2008 18:40
Alabaster wrote:
If using heat, thinking would be better to heat the area around the pistons.
Also heard of filling caliper with water, plugging the inlet, and putting the caliper in the freezer overnight.
[You already know the rest of this story -- and the risk involved].
Good Luck!
Good Luck!
- drmadd95
02 Dec 2008 09:13
I had the same issue on my bike. I used a grease gun to pop the pistons out. I wasted a good amount of grease doing it, but I didn't want to freeze the caliper with water.
Grease doesn't compress like air and it has to go somewhere. This causes the piston to pop out.
As far as cleaning it wasn't bad at all. Used the good ole finger to wipe the grease out and q-tips. Then used some good degreaser, then alcohol, then rinsed it with brake fluid. Replaced the seals, slaped her back together and it works great.
The trick part was getting the grease gun to connect to the caliper. I was lazy so I used a bolt to screw into the banjo bolt hole and then used the bleeder nipple to attach the grease gun (it was a PITA to detach the grease gun later). I suggest finding a grease gun fitting that will screw into the bleeder hole.
1979 KZ650 B (Main Ride)
1978 KZ650 D1 (sold)
1982 KZ750 (parts bike)
