motor mount trick?
- freebyrd24
motor mount trick?
27 Nov 2008 20:49
Hey everyone. I'm working on my long term 81 kz1000 k1 and ran into a bit of a snag. i'm going to start a project forum later, but just a quick question now.
the bottom mount on the front of the motor is giving me a problem. it just wont come out! the other 2 bolts came right out without issue, but this bottom front one wont. is there a secret to this? How is it set up? It looks like there are rubber bushings maybe on the inside of the holes that the bolt goes through. any ideas? thank you!
- 1981 KZ1000-K1 LTD - Long term project
1075cc Kit - New Wiseco Pistons
Sold:
- 1978 kz650 SR, 4-1 Vance and Hines Full Exhaust, Dyna-S Ignition, Accel Coils and Wires
Sold:
- grace1
Re: motor mount trick?
28 Nov 2008 04:25
g,day freeby
i,d say your right re rubbers ,your,ll prob find that grunge and rust has seized the bolt to the rubbers ,you,ll need a small drift punch and some wd40 spray to break that seal
good luck
graeme
good luck
graeme
bendigo australia, gold mine country
MY COLLECTION 1978 B3 KZ750 AND 1980 GS1000G
28 Nov 2008 07:54
OR-
the bolt may be seriously corroded to the metal tube inside the rubber insulator. I ended up using copious amounts of penetrating oil (penetrates better and leaves less sticky residue than WD40), a small torch to heat the bolt a bit, and a BFH (aka Harley tool). Keep in mind that the energy applied to the stuck bolt is being transferred to nearly 30-year-old cast aluminum. Caution, patience and persistence are the most importatnt tools.
- freebyrd24
28 Nov 2008 10:09
i have been giving this thing a lot of force and let the part soak overnight. it is seriously stuck. this is a huge pain. the bolt spins with a little force, the nut came off of the bolt, but its just stuck. i'll try to add some heat and just keep at it. i have a couple hours already into the bolt, its very frustrating.
Sold:
Sold:
- MFolks
28 Nov 2008 10:58
I've used a spray on product called "Kroil" that gets under rust and should work well for you in this situation.
- freebyrd24
28 Nov 2008 22:56
Well I finally got that stubborn bolt out! i ended up catching the rubber on fire that was over the bolt, then when I put it out, i peeled it out of the way and was able to get parts blaster on it and it finally gave way. what a PITA!!
Sold:
Sold:
