piston stuck in caliper
- wireman
19 Feb 2006 13:52
ive got a rear disc brake caliper with stuck pistons,tried blowing out with air like i normally due but they are stuck!any ideas?:whistle:
- steell
Re: piston stuck in caliper
19 Feb 2006 14:34
Have you tried hooking it back up to the brake line and using brake line pressure to pop it out?
I think you will get a lot more presure that way.
- wireman
19 Feb 2006 14:42
this one hasnt been on a bike in a long time,i wonder if there is something i can soak it in that wont destroy the aluminum housing?i am going to powder coat the housing and replace the piston and seals if i can get it apart otherwise i guess i can dig up another caliper.does anyone know of a caliper off a newer bike that can be used with stock 1000 hub and rotor and be mounted on bottem side of swingarm without a major amount of hassle?
- steell
19 Feb 2006 14:48
If you can get the boot and seal off, maybe soaking it with PBBlaster (penetrating fluid) would help. Might have to let it soak for a day. Maybe even heat the caliper?
- Duck
- e vica na i sau na ga
19 Feb 2006 15:53
Is this that lovely triangle shaped caliper with a circle and wings
at the wide end? PITA! Suggest filling the cylinder with MMO
(Marvel Mystery Oil) or ATF. Then set the thing piston down in a small
basin with enough ATF to come as high as the inner seal. Give it a try
with hydraulics after a day of soaking. If it's not all the way in the cylinder
it will help to alternately push it in a bit and work it out a bit.
-Duck
Post edited by: Duck, at: 2006/02/19 18:55
-Duck
- arobsum
19 Feb 2006 16:30
i soaked mine in some carb cleaner for awhile to soften the rubber up..when i hit it with the air it popped right out. of course it takes paint off too.
- waterman
20 Feb 2006 05:25
I had to go the PBBlaster route last year and it worked. Since I already had decided that the piston was toast, I got a little rough working it back and forth until it came out.
- wireman
20 Feb 2006 21:35
got one side out today,ill let the other side soak till tomorrow and try it again.:whistle:
- Shoe48
- Live each day as it is your last
21 Feb 2006 16:51
I made a plug with a grease zerk in it , Just screw it into where the brake line goes , Just hook it up to the grease gun, Pump away , one will move sooner than the other ,, use a C Clamp to hold it back a bit ,, Just keep loosening up the clamp as the piston comes out ,, Kinda messy after the pistons come out ,, BUT it does work well
Maybe for that extra stuck pistons :lol:
- Snakebyte
22 Feb 2006 04:22
Nice ideer with the grease. I just use a air nozzle with a rubber end and place a rag between the piston and braket. Then just blow it out. Watch your fingers with this one. You may want to cover your ears too.:whistle:
