once it gets a little warmer
  • fixer5000
  • fixer5000's Avatar Topic Author
19 Feb 2006 10:57
#24883
im going to put all this stuff on my bike!! thanks for all the pro's and cons about dual discs up front. everyones advice was weighed and understood...steve
Post edited by: fixer5000, at: 2006/02/19 13:59
Post edited by: fixer5000, at: 2006/02/19 17:51
1978 kz650b pretty much stock
massachusetts
  • RetroRiceRocketRider
  • RetroRiceRocketRider's Avatar
  • ...bring in the machine that goes PING!
Re: once it gets a little warmer
19 Feb 2006 11:02
#24886
I did the dual-disc conversion on my 650 about 2 years ago, and I wouldn't go back to the single disc if someone paid me! B)
If you have any questions or run into any problems, don't be afraid to ask.
Quite a few members here have tackled the same conversion before, so there's quite a talent pool of info available. ;)
Covina, So Calif!
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
89 GSX1100F Katana = SLEEPING :-/
  • fixer5000
19 Feb 2006 11:08
#24890
so far the only problem ive had is today when i was making sure i had all the hardware i found one of the mount holes in the caliper was buggered...dont it figure after i rebuild em i find that? luckily ive been collecting a lot of parts for this switch and had a spare one. 10 mins later all switched...steve
massachusetts
19 Feb 2006 11:16
#24893
If you haven't already got one, and can afford it, I'd suggest getting a brake bleeder kit.
It will not only take out the hassle and effort of bleeding the brakes manually, but also is more thorough IMHO and takes about 1/3 of the time to do.
The one I have is a Miti-Vac, and also can be used to test vacuum pressure. Best $24 I've ever spent too!
Here are a couple that are listed on the Harbor Freight website:
da.harborfreight.com/cpisearch/web/search.do
Covina, So Calif!
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
  • fixer5000
19 Feb 2006 11:54
#24904
i have a small electric powered vacuum pump and an old well sealed jiffy jar with fittings attached that ive used many times on my vehicles...works for me. one question though..should i bleed out one side first or alternate from one side to the other?...steve
massachusetts
19 Feb 2006 11:59
#24906
After filling both lines with brake fluid, you would want to bleed one side at a time.
And just like with a car, bleed the caliper that is the farthest away from the master cylinder first.
I know that's kind of hard to do on a bike. But IIRC, there is a minute diff in brake hose length between sides on our particular bikes.
Covina, So Calif!
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
