Shock question.
  • coppertales
  • coppertales's Avatar Topic Author
Shock question.
21 Nov 2008 10:49
#248665
Does anyone make a shock for a 1982 KZ1100A2 that works ok but does not cost an arm and a leg? The ones on my bike are completely shot. It doesn't help that I weigh 250 lbs and have the Vetter saddlebag setup on it too. Thanks....chris3
1982 KZ1100 A2
1982 1100 SPECTRE
1982 1100 SPECTRE
  • hardr0ck68
  • hardr0ck68's Avatar
  • Who put the what in the where?
Re: Shock question.
21 Nov 2008 15:35
#248689
you could use hardly shocks. I have a set of sportster take offs that I picked up on ebay for 12 shipped on my 650.
I had to swap the shock bushings and the lower shock mount is a little to big (i just ground it down, or you can bend the lower shock mount slightly)
they are cheap and they work....
1977 kz650 c1
bought it because I was told it would never run again...I like to prove people wrong.
  • bountyhunter
  • bountyhunter's Avatar
Re: Shock question.
21 Nov 2008 15:57
#248699
You sound like a good fit for the ones JC Whitney sells. They are decent quality (for cheap shocks), I ran a set for about 20 years. The only thing is they come with the stiffest springs which was a poor match to me because I only weigh 160. For you, they might be spot on.
www.jcwhitney.com/autoparts/Search?catal...1&sku=shock+absorber
www.jcwhitney.com/autoparts/Product/Pr-p...p?Ntt=shock+absorber
