Head light Mounts/Ears
- KawiConvert
18 Nov 2008 00:04
I have a set of the cheap 12.00 headlight mounts and I am looking for something a little sturdier and shorter. I am trying to find ones that are about the length of mounting in the middle hole on the cheap sets. Does anyone know of a good set out there that will work for the 650? Mainly need the shorter length and a solid mount type.
Thanks!
Thanks!
1978 KZ650 D1 ~ Carb jetting: 107.5 & 20 & 4th groove with pods and 4-1 Exhaust
Re: Head light Mounts/Ears
18 Nov 2008 02:03
KawiConvert wrote:
Perhaps a KZ650 LTD style headlight mount isn't on target here
, but found this ebay listing.
Item number: 270303598765
Standard model ears appear under Item number: 220306092250
May find something more economical elsewhere, and without deal-killer shipping costs.
Good Luck!
Thanks!
Good Luck!
- JMKZHI
Last edit: 04 Dec 2008 09:50 by JMKZHI.
- Locozuna
18 Nov 2008 06:19
This is my 76900LTD it has a pretty sturdy headlight mount that is kind of minimal. Shows off more of the tube. My bro built her but I think it's a stock mount. He even got another one off e-bay and put it on the 650 if I remember right. There is also one like it but with chrome wire used on 550LTD's that would work.
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
"If you seek for Eldorado!"
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
- KawiConvert
18 Nov 2008 07:15
JMKZHI wrote:
Yes and its a 78 kz650 SR. I am using a Acewell speedometer and am cutting off some material on the front brake divider to allow more clearance for the headlight to move down and back.
Locozuna,
That one looks kind of like the stock one, but a lot closer to the tubes. I'll look and see, but I don't know if I can change mine wthout ruining the chrome.
Are you trying to move the headlite bucket closer to the frame?
And it wouldn't hurt to go ahead & mention what model 650 it is. JMK.
Locozuna,
18 Nov 2008 09:04 - 18 Nov 2008 09:08
KawiConvert wrote:
If not already considered, could perhaps eliminate the divider altogether by fitting a dual outlet banjo at the master cylinder and running twin brake lines.
The KZ900-B1 (LTD) does indeed have a minimalist but sturdy headlight mounting bracket, but I didn't realize it would also fit a KZ650.
Good Luck!
... am cutting off some material on the front brake divider to allow more clearance for the headlight to move down and back....
Good Luck!
Last edit: 18 Nov 2008 09:08 by Patton.
- KawiConvert
18 Nov 2008 11:51
Patton wrote:
I could, but I like the look of the single line off the bars. It won't be hard to cut off nearly .25" off the mount side. Also I need to plug the brake switch hole, I am using a non-oem MC and it has a switch built in which will work with the kill switch that I am using.
Too many things on my bike needed to be replaced and it was more cost effective to go with newer parts off of newer style bikes than to find good condition OEM. I will have to take a look at getting a headlight mount like that. Otherwise I may end up making one.
KawiConvert wrote:... am cutting off some material on the front brake divider to allow more clearance for the headlight to move down and back....
Good Luck!
- Locozuna
18 Nov 2008 12:40
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
- KawiConvert
18 Nov 2008 13:51
Locozuna wrote:
Definitelly hits the "stout" requirement
. "The only thing that survived the wreck was the headlight bracket". Its a nice idea, but is essentially what the stock one did, just a different setup instead of the rod with tabs. Hmm, gotta keep on looking.
- Locozuna
18 Nov 2008 14:58
KawiConvert wrote:
You wouldn't believe the sleep I lost before I put this bracket on my bike. DREAMS of riding long lonely stretches of desolate highway at night when "CrUnCh!" my headlight falls off and goes bouncing off into the inky woods. That's when the mooon goes behind a cloud bank........see you'll be sorry putting a flimsy lil' bracket on there! :whistle: :whistle: :pinch: :pinch:
Locozuna wrote:
Definitelly hits the "stout" requirement. "The only thing that survived the wreck was the headlight bracket".
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
- KawiConvert
18 Nov 2008 16:59
It did get me thinking of how to replicate the stock bracket (only shorter arms/ears) out of sheet aluminum. Cut it out, bend it up, polish it, and go. And I can add some fancy design on the ears. Hmmm.
I agree about the worry, I have 0 miles on my bike and already I can imagine trying to follow the bouncing light as I try to go down the road.
18 Nov 2008 20:23
With a chrome headlight shell, another option might be a chromed KZ900-B1 bracket, which to some folks may seem less noticeable.
