Raking questions.......
  • iroc355
  • iroc355's Avatar Topic Author
17 Nov 2008 09:01
#247950
hey guys, just a few ?'s bout raking a kz900 frame. first off, is it better to start with a new steering head or to re-use the original and why?
if a new steering head is needed where is the best place to get on from?
also what methods have you found to work best?
thanks!
  • Royal1MC
  • Royal1MC's Avatar
  • Is it just me, or is it just great to be on a KZ
Re: Raking questions.......
17 Nov 2008 14:06 - 17 Nov 2008 14:07
#247978
Here is a trend started not to long ago regarding this topic:
kzrider.com/index.php?option=com_kunena&...ew&catid=5&id=245860
*1980 Z1-R (current))
*1978 KZ1000 LTD w/ Z1-R frnt end (sold)
*1977 KZ650 B1 (sold)
Los Angeles, CA
Last edit: 17 Nov 2008 14:07 by Royal1MC. Reason: url link
  • racer54
  • racer54's Avatar
17 Nov 2008 16:54
#248000
Usually, the two ways it's done is to cut the top backbone frame tube and cut out about an inch...depends on how much rake you want...then after heating neck area, pull steering head back to meet cut and reweld the tubes together. Best to put a plug inside the tubes to line them up. You just have to be sure you pull straight back for obvious reasons. Other way is to cut original head tube at the angle you want and then weld another tube to the original tube. It will extend the front-end farther forward slightly but give you more room at the front of the tank. The first way will have the head tube hitting the tank and you will have to modify the tank or move mounting points rearward a little.
  • timebomb33
  • timebomb33's Avatar
17 Nov 2008 17:00
#248004
use the second that is the method i used it is a lot stronger.
I THINK MY POWERBAND BROKE
  • PLUMMEN
  • PLUMMEN's Avatar
17 Nov 2008 21:09
#248043
i prefer the looks of the 1st way if its done right,just gusset the backbones/steering head area when your done.on mine i think im going to have frame put in jig and have steering head completely removed since its not straight and have a new head welded back on like origional but with a couple degrees of rake added B)
  • iroc355
18 Nov 2008 17:51
#248177
thanks guys! does anyone have pics of either of the ways, like close up of the steering head area, that would be greatly appreciated!
  • timebomb33
18 Nov 2008 20:18 - 18 Nov 2008 20:24
#248222
take a look at my bike sorry it wouldn't load go to the z1900 gallery picture 242that is one bike with the neck raked not the frame.
Last edit: 18 Nov 2008 20:24 by timebomb33.
  • timebomb33
18 Nov 2008 20:57
#248239
i'm going to try loading a picture of my hotrod again
