gs wheel with my gs arm ?
  • donthekawguy
  • donthekawguy's Avatar Topic Author
17 Nov 2008 05:33
#247893
I picked up a gs1100 wheel with a 3.5 inch wide rim from ebay. Will this wheel work with my gs arm? The only thing I am concerned about is the offset. Guess I could check it when the wheel gets here but thought I would check in here first. If I could just bolt the arm up and use the gs wheel it would save a bunch of trouble getting the spacer situation figured out. BTW Harbor Freight has small metal lathes for around $250 that would be perfect for cutting spacers.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
  • PLUMMEN
  • PLUMMEN's Avatar
Re: gs wheel with my gs arm ?
17 Nov 2008 06:06
#247902
boo,hiss from the audience!:laugh:
  • timebomb33
  • timebomb33's Avatar
17 Nov 2008 06:37
#247913
it should pretty much bolt right up.it sounds like a non stock wheel if it's 3.5 wide i think stock gs wheels were 2.85 if im not mistaken
I THINK MY POWERBAND BROKE
  • mtkawboy
  • mtkawboy's Avatar
17 Nov 2008 13:45
#247975
I had one on mine and took it back off, didnt like the look. Swingarm fits with just a spacer and you have to use the Zuki shocks
  • donthekawguy
18 Nov 2008 06:21 - 18 Nov 2008 06:28
#248095
I'm hoping the wheel won't be too noticeable. If it is I'll go with the kz hub and wider rim. Here is the wheel. I might even clean the red paint off. :laugh:
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
Last edit: 18 Nov 2008 06:28 by donthekawguy.
  • timebomb33
18 Nov 2008 06:57
#248100
that looks pretty cool but id leave the red rim and jusy clean the spokes up. old drag set-up from the look of it. i won two championships and two wally's with a wheel just like that.
  • donthekawguy
18 Nov 2008 23:08
#248260
My plan is to powdercoat the rim black, clean and buff the spokes and clean up the hub. I'll do the front wheel also. Maybe replace the bearings in both wheels. Other than that I'll just clean everything up real nice before I move on to the forks and triple bearings.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
  • gane
  • gane's Avatar
19 Nov 2008 19:46
#248419
Don, offer this, since you've already stepped up to gs 1100 swingarm, why not lace a wm4 17" rim? w/530 chain and a little squeeze at brake stay arm a 160/70-17 fits w/a little fingers clearance on both sides, requires no new spacers at axle, uses gs slave,allows current rubber and in a width that dwarfs the old 4.25's. G. PS a call to Buchannans' frame works should yeild a quote for a rim & spokes. ten years ago, my total was @ $180.00 in parts.
[img][/img] 1977 KZ1000A1
  • donthekawguy
20 Nov 2008 00:17
#248454
I would but I want to keep this as cheap as possible. It's just my daily rider and I can get a 140 or 150 tire on it. With my 78 I'll be dumping a ton of money in it so I'll go with the more spendy parts.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
