shaft drive rigid frame
- paradon
16 Nov 2008 11:41
i want to make my 83 550 shaft drive into a rigid frame. but i'm not sure how the rear wheel comes off, and i dont want to make it to much of a hassel to get off when i need to change it or the brakes. to me it looks like if you pull the axel out it should just drop down, but i'm not positive cause i've never had the rear wheel off. any info would be helpful
- timebomb33
Re: shaft drive rigid frame
16 Nov 2008 12:00
undo the torque arm going to the backing plate, undo the brake rod,pull the axle the spacer should come with it and pull the wheel away from the hub and it should drop down and be easy to remove from there.
I THINK MY POWERBAND BROKE
- paradon
16 Nov 2008 12:30
thanx, i thought it would still come out but i just wanted to make sure befor i have everything welded up
- timebomb33
16 Nov 2008 15:34 - 16 Nov 2008 15:34
yes you won't have any problems taking it out. before you put back together clean out the engaugement splines on the wheel and on the differential and pack freash wheel bearing grease in the splines. how low is that bike going to be it looks aweful low.
Last edit: 16 Nov 2008 15:34 by timebomb33.
- paradon
16 Nov 2008 18:32
i havent masured, but the drive shaft is level and it rolls with out binding. i've herd they will bind if there too low. other then that, i just kinda flyn by the seat of my pants.
- timebomb33
16 Nov 2008 20:12
actually that is what i was talking about the seat height it seems to be a bit on the low side.
- paradon
17 Nov 2008 06:23
the seat height has droped prolly 2 to 3 inches, nott sure the exact amount.theres enough room for a battery and the other few parts i need to keep.
