oopsies!
11 Nov 2008 17:00 #246901 by PLUMMEN
oopsies! was created by PLUMMEN
got to feeling ambitious today and decided to drill out the sleeves in the downtubes for bigger motor mount bolts on my never ending z1 project,for some reason i couldnt find a sharp 7/16 bit so i figured id try a 1/2"!:S well now im having some oversized sleeves made so i can run bigger bolts!:laugh:
11 Nov 2008 17:10 #246905 by timebomb33
Replied by timebomb33 on topic oopsies!
smrt.what did we learn from this class. haste makes waste right mr.plummen
I THINK MY POWERBAND BROKE
11 Nov 2008 18:07 #246927 by Old Man Rock
Replied by Old Man Rock on topic oopsies!
Uh Plummen, you do realize that 1/2" is 8/16ths thus equating to 1/16th larger than 7/16ths.... :huh: :dry: :whistle:
Way to go, you have now joined the bone head club which I started when I busted a hole in my lower case....
Sorry brother... I feel your pain.
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
11 Nov 2008 18:28 #246930 by timebomb33
or if you prefer to the youngsters in the class 7/16 is roughly 11 mm. 1/2 is roughly 13mm. 2mm more bigger dohhh.
11 Nov 2008 18:56 #246933 by PLUMMEN
Replied by PLUMMEN on topic oopsies!
thats allright ill just have really beefy motor mount bolts to go with my extra beefy motor mounts !:laugh: it gave me an excuse to figure out a couple other weak links in the ol kaw frame design while im at it!im going to try and have it ready to go on the frame jig in a couple weeks to get the ol steering head chopped off and a new one installed and rest of frame straightened so i can finish steering head bracing.i want tomake sure im going in a straight line when i tie one on with timebomb!:laugh:
11 Nov 2008 19:05 #246934 by PLUMMEN
does anybody have the dimensions for one of those new sealed type batterys that can be laid on its side?while i was cutting and grinding and filing today i decided the z1 battery box was going to cause issues with mounting my coils under seat so i removed the mounts!so i guess i should start designing a battery box where i can load it from the side unless somebody has 900 battery box theywant to part with!(see cheap!:laugh: )
11 Nov 2008 19:10 #246935 by timebomb33
funny you should ask my friend what size[amp hour rating] were you planning on procuring.
11 Nov 2008 20:11 #246942 by PLUMMEN
if i canfind a 76 900 battery box ill just use regular battery,if i have to design /build one i need the smallest one i can get that will turn the world over!:laugh: i need to figure out how to stuff coils,a battery nitrous and fuel injection controls and all the regular crap under the seat and still have room for a bottle on top/front of swingarm!:S
11 Nov 2008 20:40 #246951 by timebomb33
i have one of those battery's right here ill give you the measurement's the battery i have is an a.g.m from napa auto parts.it is an etx14. the measurements are as follows L 5 7/8" W 3 1/4" H 5 5/8" HOPE THAT HELPS BROTHER PLUMMEN
12 Nov 2008 04:08 #246980 by StreetfighterKz
Replied by StreetfighterKz on topic oopsies!
I have the old one from my 900. It doesn't have the piece that actually holds the battery in but I'd probably let it go for shipping (~$10). I can snap a pic if you want me too.
Later, Doug
1978 z1000 Streetfighter
1976 z900 Stripfighter (work in progress)
1983 Gpz750 Resto-Mod
1989 Vmax
12 Nov 2008 04:35 #246988 by PLUMMEN
that would be very helpfull,pm me an adress B)
12 Nov 2008 04:36 #246990 by PLUMMEN
hold that thought there young fella,let me see if i can make the kz box work.THANX B)
