Swappable Side Covers ???
  • Summerheat
  • Summerheat's Avatar Topic Author
  • Wanted at 17 Got it at 47 Worth The Wait!
11 Nov 2008 07:46
#246792
I have a 1976 KZ900-A4. "HAD" two nice OEM side covers with badges.
Unfortunately lost one on the highway and would like to find out if 1977-1978 KZ1000's are an exact OEM match or do I need to stick with 1976 KZ900.
Really want to stay OEM if possible and appreciate any insight you can give.
Thankks
1976 KZ900-A4
  • PLUMMEN
  • PLUMMEN's Avatar
Re: Swappable Side Covers ???
11 Nov 2008 08:19
#246797
76-78kz and 79-80 ltd should physically fit the same,emblems should also fit same holes.drill a 1/8" hole in top front corner of the covers before you paint them and use a little piece of that little chain they use on finger nail clippers to wrap around frame tube as a safety chain to hold cover if it pops out of rubber grommets,you might also want to replace the grommets B)
  • timebomb33
  • timebomb33's Avatar
11 Nov 2008 10:02
#246815
to hold them on i drill a 3/32 hole about 5/16 of an inch dow from the end of the locating pins and push them in place then i use ether cotter pins or spring pins push thru the holes to keep them in place in the rubber grommets.
I THINK MY POWERBAND BROKE
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
11 Nov 2008 10:07
#246818
Pretty much like Plummen said, the sidecovers with the same OEM numbers (except for color) are KZ900A4, KZ900A5, KZ900B, KZ1000A1/2/A2A, and KZ1000B1/2. Strangely, the B3/4 have different numbers but I also think they will fit.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • Summerheat
11 Nov 2008 10:07
#246819
Thanks. Yeah I replaced the gromets as well, but we had a fall run that included some highway action and I tweaked the throttle a bit and well, I guess new didn't stand a chance either.
Will be sure to secure new ones once back on bike.
1976 KZ900-A4
  • MFolks
  • MFolks's Avatar
11 Nov 2008 11:06
#246828
I think redline cyle has side covers at www.redlinecycle.com
  • Summerheat
11 Nov 2008 13:10
#246846
Thanks everybody. You have raised my hopes with a larger selection to find replacements.
1976 KZ900-A4
  • PLUMMEN
  • PLUMMEN's Avatar
11 Nov 2008 16:00
#246878
my problem with doing it that way is if you ned to get em off quick in an emergency it aint gonna happen!:(
  • timebomb33
11 Nov 2008 16:01
#246880
true but you wont lose them either.
  • PLUMMEN
  • PLUMMEN's Avatar
11 Nov 2008 16:13
#246885
safety chain has always worked me anywayB)
11 Nov 2008 16:16
#246886
The earlier thread shown below contains another neat solution offered by none other than the world famous locozuna who never met a sidecover he didn't like. :laugh:
clip-n-wire
Good Luck! :)
  • timebomb33
11 Nov 2008 17:25
#246915
see you are never to old or experianced to learn something new that is an awesome tip.
