brake rotors
- Indymick
brake rotors
07 Nov 2008 08:40
ok now that i have my swingarm bearings taken care of. My next question is about the brake rotors they seem to be strait (no vibration) but the have very very fine groves basic wear I think and discoloration. I took them to a race shop to see what they could do. They are road worthy just dont look as nice as they could. Any help!!!!!1:unsure:
1979 KZ650-c3
- MFolks
Re: brake rotors
07 Nov 2008 10:11
It's almost impossible keeping brake rotors from getting grooves cut into them. The act of braking along with the normal grit,dust and other polution in the air and being close to the ground soon turns the pristine disk surface grooved and scarred.
Short of having them turned (and possibly be too thin)I'd get a new set of pads/pucks and go riding.
- PLUMMEN
Re: brake rotors
07 Nov 2008 10:13
take em to a shop that surfaces car/truck flywheels
- dman3998
Re: brake rotors
07 Nov 2008 21:02
I sent mine to a shop in Portland that grinds them to perfection on a surface grinder. most car brake machines cant do these rotors.
give this guy a shout for 50 bucks you will not be disappointed
Chris Schumann (speedracer741_@hotmail.com)
dman
dman
Dman
SE Idaho
"Smart only goes just so far, STUPID is UN-limited"
79 KZ1000 LTD
Honda XRL650L
Yamaha RD350B
Yamaha DT400B
SE Idaho
79 KZ1000 LTD
Honda XRL650L
Yamaha RD350B
Yamaha DT400B
- bountyhunter
Re: brake rotors
07 Nov 2008 21:18
Unless a rotor is deeply scored or warped, no reason to cut on them. Fine lines don't hurt anything.
- oldcoldankles
Re: brake rotors
08 Nov 2008 06:23
PLUMMEN wrote:
+1 When you need to resurface rotors, do not skim them on a brake lathe, but take them to an engine machine shop and refinish them on a flywheel refacer, making sure the thickness stays uniform. It takes off only a few thousandths, leaving a nicer finish without chattering, eliminates the phonograph record groove effect, takes out the hard spots better, and gives you really smoooooooth braking for about $20 - $30 a rotor. The minimum rotor thickness will be found in your service manual, or stamped on the rotor. Worked great on my bikes and Corvette too.
Peachland BC
1981 KZ1000 CSR M1
1983 KZ550 LTD M1 (Shaft)
1989 Corvette coupe
1981 KZ1000 CSR M1
1989 Corvette coupe
- PLUMMEN
Re: brake rotors
08 Nov 2008 10:18
it costs me like $8 a rotor around here to have it done
