KZ1000 Swingarm versus KZ650 Swingarm
- wireman
Re: KZ1000 Swingarm versus KZ650 Swingarm
14 Nov 2006 18:05
yeah thats fine if you have a disc brake rear hub ,if you have drum rear brake youll need to make bracket for brake stay arm
- ratmeister
14 Nov 2006 18:08
My bike has a rear disc, and my arm and brake mount perfectly, my only problem is with the wheel hub, brake arm, 650 spacers and the chain adjusters I need to lose about 1/4"...
- wireman
14 Nov 2006 18:15
make sure you center your wheel up really good before you start making spacers,ive got a bunch of rear spacers but i think they are all at plating shop.
- ratmeister
14 Nov 2006 18:22
Can I just machine mine down? 1/8" on each side of the hub would do it...The spacer on the chain side measures 1-1/2" OD and is 7/8" long and the other one is a different shape (like an "H" and is 1-1/4" long and the side facing the outside is 7/8" OD by 1/8" wide.
Anyone have some measurements of other spacers or know of any others that would fit?
- wireman
14 Nov 2006 18:25
yeah if you can machine yours down thats fine,just check your measurements really good some of these bikes werent really straight even when they were new;)
- ratmeister
14 Nov 2006 18:31
At least with my swingarm off I did verify that it was bent. The new one is nice and level. Now I need to modify my newly aquired massive honda magna shocks so they fit the top bolts...
I really would rather find some spacers that fit instead of machining mine. So if anyone out there knows of some that would fit let me know please.
Thanks...
Thanks...
