New chain and sprockets help
- Tinkerinmatt
04 Nov 2008 16:01
my chain is so stretched that it doesnt ride in the teeth of the sprocket anymore. I looked on Z1 for chains and sprockets and they seem way overpriced. what should i expect to pay for a new chain and sprockets? and where can i get them? its a 1978 KZ1000A2 with 28k on it. while im in there, is it worth it to upgrade to a larger rear sprocket? and if so what size gives best performance/highway comfort comprormise
thanks
thanks
- steell
Re: New chain and sprockets help
04 Nov 2008 17:46 - 04 Nov 2008 17:48
~$140 or so for a X-ring chain and both sprockets is over priced?
Well, if you want to go really cheap, then look for number 60 industrial chain (same size as 630), that will save you some bucks on the chain, but the sprockets will still cost the same.
Can't help you on the sprocket size for the 1000, I'm a 750 guy.
You can't talk about cheap chain and performance in the same post, they are mutually exclusive.
Last edit: 04 Nov 2008 17:48 by steell.
- Biquetoast
- King Jeremy The Wicked
04 Nov 2008 18:18
steell wrote:
Except, of course, that you will have to replace the sprockets probably 2 or three times (and that means 1 or two more chains) in the span of time that you would have used one x-ring chain and sprocket set. So don't forget to calculate the proce two or tree times as an equivalent.
:lol:
Well, if you want to go really cheap, then look for number 60 industrial chain (same size as 630), that will save you some bucks on the chain, but the sprockets will still cost the same....
(1.) '75/'76 KZ400D - Sold
(4.) '75 KZ400D - Sold
kz750twins.com
kz750twins.com
- MFolks
04 Nov 2008 18:37
The website
www.gearingcommander.com
covers chain speeds and sprocket sizes for gearing changes.
- bountyhunter
04 Nov 2008 22:19 - 04 Nov 2008 22:22
JC Whitney sells cheap, generic brand drive chain for people not obsessively fond of keeping their left leg in original condition....:laugh:
Even that junk would run maybe $30 - $40, so saving a little on a chain doesn't make sense to me.
www.jcwhitney.com/autoparts/Product/Pr-p...earchGroup?Ntt=chain
Last edit: 04 Nov 2008 22:22 by bountyhunter.
- dman3998
04 Nov 2008 22:26
DO NOT SKIMP on chain!.. your taking a big chance if you get a cheap one and it fails. and it WILL it's only a question of time. buy the best chain you can AT least OEM equiv. the no name import junk on fleabay is your life or serious tranny damage is at risk.
Dman
SE Idaho
"Smart only goes just so far, STUPID is UN-limited"
79 KZ1000 LTD
Honda XRL650L
Yamaha RD350B
Yamaha DT400B
SE Idaho
79 KZ1000 LTD
Honda XRL650L
Yamaha RD350B
Yamaha DT400B
04 Nov 2008 23:14 - 05 Nov 2008 12:55
Tinkerinmatt wrote:
Imo Z1E's prices for chains and sprockets are very reasonable, and for either o-ring or newer xw-ring style chain.
Raising or lowering the overall gear ratio with sprocket size different than stock has little effect on attainable top speed, but can enhance acceleration with buzzier higher rpm cruising at same road speed, or impair acceleration with lower rpm cruising at same road speed.
Have experimented with both larger and smaller countershaft (front) sprockets, before returning to stock size. Am thinking one tooth up or down on the rear sprocket would hardly be noticeable.
The peanut gallery has spoken. :lol:
Good Luck!
thanks
Good Luck!
Last edit: 05 Nov 2008 12:55 by Patton.
- Old Man Rock
05 Nov 2008 05:22
Regardless if you're keeping with the 630 or converting to 530, chains average at $100 - $150 pending the manufacturer and oil "ring" configurations.
Stock counter sprockets ~ $15, rears ~$30 up pending steel vs. aluminum, design, colors etc... 2 teeth on the rear isn't going to provide a drastic change. What are you looking for, more acceleration, easier cruising etc...
Think dirt bikes:
Larger rear equates to better hill climbing, easier wheelies, decreased road speed.
Smaller is the reverse of larger.
Look at it this way, that's probably a 30 year old chain on your bike and it finally stretched to being no longer worth a crap. Again, 30 YEARS!!!!
As already mentioned, don't skimp on the chain and get a $60 one (Non O-ringed) for you'll only be kicking yourself in the ass for doing it. Probably leave you stranded one day.
Sprockets are cheap, so for ~$160-$180, you replace all and ride safely for the next 30 years and happily knowing you're covered.
OMR
Think dirt bikes:
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- BSKZ650
05 Nov 2008 09:31
I did a little shopping when I did mine, z1 was in line with all the others, but the big advantage with them, you can get a real person on the phone who knows the bikes, and can make a good recomendation.
Also if you buy the o ring chain, guy the install tool,,, saves fingers,, dont ask how I know
77 ltd1000, current rider
76 kz900, just waiting
- 77_650B1
05 Nov 2008 09:40
I've got an x-ring chain, I think I got it from Z1 or DK, not sure now, its been a few years. Huge tensile strength means I'll never have to worry about it on my bike, it's made to work on huge power new 1000cc bikes. I havent had to adjust it in ages, it takes forever to stretch at all. Its an RK chain.
1977 KZ650-B1
-Dual Discs
-Dyna-S
-WG Coil Mod
-Alloy Wheels
-Dual Discs
-Dyna-S
-WG Coil Mod
-Alloy Wheels
- Royal1MC
- Is it just me, or is it just great to be on a KZ
05 Nov 2008 13:13
MFolk, Good Link to Gearing Commander. Very helpful.
*1980 Z1-R (current))
*1978 KZ1000 LTD w/ Z1-R frnt end (sold)
*1977 KZ650 B1 (sold)
Los Angeles, CA
Los Angeles, CA
- timebomb33
05 Nov 2008 20:44 - 05 Nov 2008 20:49
i run on the highway 15 front 33 rear,if im going to the track or hot-rodding around with some freinds i run 15/39 it is a bit steep for every day riding but it sure is fun at party's i mean from stoplight to stoplight.and please don't cheap out change your chain and sprokets at the same time you will get a whole lot more life out both if you use top quality as well use good name chain and sprockets personally i have had good luck with ek or did chain and i try to use sprocket specilist or p.b.i when ever i can.
I THINK MY POWERBAND BROKE
Last edit: 05 Nov 2008 20:49 by timebomb33.
