??? for who has done a gs swingarm swap
  • donthekawguy
  • donthekawguy's Avatar Topic Author
01 Nov 2008 02:46
#244900
Ok I found a ton of 16 inch 40 spoke wheels on ebay. How wide of a wheel will work in the gs arm? The one I'm looking hard at is 4 inches wide. I'm thinking that will be too wide. Maybe a 3.5 or something close to that? I'm going to powdercoat both rims black and get new spokes for both wheels. I found a bunch of rusty rims but they are off of Hardley's. Maybe I won't mention that to anyone else. :laugh:
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
Re: ??? for who has done a gs swingarm swap
01 Nov 2008 04:22
#244903
Although I am not an excessive fan of OldKawMan, check out his site www.oldkawman.com/ where he shows a suzi swingarm with a 150/80 16" on a KZ1000...looks good:)
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • donthekawguy
01 Nov 2008 06:48
#244910
Cool now I have the tire size I just need to know how wide of a rim I should have. Maybe a 3.5 or 4 inch?
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
  • Old Man Rock
  • Old Man Rock's Avatar
01 Nov 2008 07:57
#244915
Something I had when looking into the GS1100 swingarms..
Maybe it will help, maybe not...
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • StreetfighterKz
  • StreetfighterKz's Avatar
  • Away
01 Nov 2008 08:10
#244918
With some minimal work you can get a 5.5x17" rim in there with a 180mm tire into a Gs1100E arm.
Check out how to do it here . Scroll down to where it says "180mm Tire Upgrade."
So a 4" wide rim should be no biggie.
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
  • gane
  • gane's Avatar
01 Nov 2008 18:44
#245066
Don, I did this mod on my '77 kz1000 10 years ago.(when 18" tires were still current) "81 GS1100E swingarm, SUN wm 3.5,18". aluminum hoop,swedged stainless steel spokes & nipples. all that was required was a call to Buchanan's frame shop in Ca. stating hub origin and lace pattern. and in @ a week, I recieved a rim & spokes.which were and are exact fit. If I were to do it again, I'd opt for 17" simply for access to a wider range of rubber compunds/.availibility. w/wheel centered, I have @ 5mm clearance between chain (530) and a 150 tire.(brake stay arm required tweeking) w 3.5 rim, tire profile is optimum at 150, wider tires less so. hope this helps G
[img][/img] 1977 KZ1000A1
  • timebomb33
  • timebomb33's Avatar
01 Nov 2008 20:40
#245076
one of the guys i race with has done the conversion and he uses 4.25" sun rim and has no problem i have a3.5" on my gs swingarm and have no clearance problems at all.
I THINK MY POWERBAND BROKE
  • donthekawguy
02 Nov 2008 22:51 - 03 Nov 2008 01:17
#245305
Woops I said 16 inch and meant 18. It will be a little harder to find the 18 but I have all winter. :laugh: I'll go with the 18x3.5 to make it easy on myself and to be able to get other stuff done. I'm also wondering if I should powdercoat the hubs black when I have the wheels done or just polish them up a little bit. Now off to ebay!
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
Last edit: 03 Nov 2008 01:17 by donthekawguy.
