Brake Drum relining
  • TravisGlamuzina
  • TravisGlamuzina's Avatar Topic Author
Brake Drum relining
30 Oct 2008 18:26
#244728
Has anyone relined or know anyone who relines motorcycle brake drums. I have a really nice set of lester mags and my brake drum is looking rather out of spec. I do have a resource for metal spraying them, but no machine work. I would much rather have a new drum "pressed in" anyone, anyone, Bueller?
  • PLUMMEN
  • PLUMMEN's Avatar
Re: Brake Drum relining
30 Oct 2008 18:41
#244735
ive had clutch rebuilding places reline brake shoes years ago,not sure if they have access to what you need though.isnt the sleeve installed before hub is cast,how would you keep it from spinning inside hub?:blink:
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
30 Oct 2008 18:52
#244739
bore it out and install a new ring with press fit like you would sleeve a block then drill and countersink screws,or rivit it to the hub.
  • 77_650B1
  • 77_650B1's Avatar
30 Oct 2008 19:46
#244754
Thread the outside of the sleeve and tap the hub haha. It'd work, but sooooooo time consuming.
1977 KZ650-B1
-Dual Discs
-Dyna-S
-WG Coil Mod
-Alloy Wheels
  • 893cv
  • 893cv's Avatar
30 Oct 2008 21:54
#244772
If anyone can do it it will be these folks.
www.vintagebrake.com
1980 kz1000 LTD
1978 Z1R
  • steell
  • steell's Avatar
31 Oct 2008 04:29
#244784
Any competent machine shop should be able to bore that one out and make and fit another one.
A shrink fit will be more than sufficient to hold it, no rivets/screws/etc needed.
I've spent the last few days installing new pins and bushings in a Cat backhoe, using a freezer and a rosebud torch the parts just slide together, when the temps equalize a 20 ton press won't separate them.
  • 77_650B1
  • 77_650B1's Avatar
31 Oct 2008 05:17
#244789
Or for those of us without good shops, your deep freeze and the oven on broil haha!
1977 KZ650-B1
-Dual Discs
-Dyna-S
-WG Coil Mod
-Alloy Wheels
  • TravisGlamuzina
31 Oct 2008 12:35
#244819
that is what im talking about, heat hub, freeze ring, press and when temps eq viola. now where do i get a new wear ring?
  • PLUMMEN
  • PLUMMEN's Avatar
31 Oct 2008 16:00
#244841
i want to see that ring come out without destroying the hub ;)
  • steell
  • steell's Avatar
31 Oct 2008 19:19
#244877
Getting the worn surface out is easy, just fasten it to the mill table and use a boring head with the appropriate cutting bit in the boring bar. Or, if you have a lathe with a large enough swing, it's even easier.
That's what machine shops are for :)
As for a new wear ring,, I'd probably use any of the mild steels, like 1018, 1045, etc, cheap, easy to machine, and they ought to work for the application. I'd think about case hardening it, that would give it a lot more wear resistance.
I'm only a hobby machinist, my real job is turning wrenches. :)
  • TravisGlamuzina
01 Nov 2008 14:05
#244984
my arc spray guy said cobalt tungsten, which is what he would use is 50-55 Rc. that is pretty hard. I just don't know if anyone local to me will do the machine work at a reasonable cost, besides, I just bought a GS1100 roller and will probably make a disk brake swap soon!
  • timebomb33
  • timebomb33's Avatar
01 Nov 2008 14:11
#244986
so you will have a lester mag with a slightly worn brake drum for sale soon 18" or 16"!!!!!!!!
I THINK MY POWERBAND BROKE
