KZ250 Brake Cable?????
- clutch
- I wish I had a tad more patience to do it better!
23 Oct 2008 18:41
Hey guys,
I have the bike taken apart for some preventative maintenance (chain, sprockets, wheel bearings, etc), and I noticed that my front brake cable is no good (seized up inside the rubber sleeve). I'm having issues finding anyone that carries the right cable that says it will fit my '80 KZ250 D1, but was hoping someone here either knows where to get one, or knows what other models' brake cables will fit. Any and all suggestions/ideas will be greatly appreciated.
Thanks in advance,
Clutch
Thanks in advance,
Clutch
Southern Maryland, USA
1980 KZ250 LTD (traded, but still missed)
1982 KZ750 E3 (Cafe Project) (Dyna-S, Dyna Coils, V&H 4-1, K&N Pods, 6 Sigma Jet Kit, Acewell Computer, Woodcraft Clip-ons, Custom Rewire)
1966 A1 Samurai (Restoration Project)
Wish List:
KZ1000 P (For a "touring" bike)
Z1 (need I say more?)
Wish List:
- Iceman Too
- Even the finest shoe makes a poor hat
Re: KZ250 Brake Cable?????
23 Oct 2008 19:06
KZ 250 D1 (1980) KZ 250 D2 (1981) KZ250 L1 (1982) KZ250 W1 (1983)are the models that use the same cable. Part # is 54005-1022. And these guys
www.kawasakimotorcycle.org/forum/vintage...ont-brake-cable.html
(:blink: may be you???) may have found one. (Here
) Hope it helps ;) IceMan
1979 KZ 1300 (Under Repair)
1999 V-Max (Gonna ride it till the Kow comes home)Sold Kow came home
1980 KZ1300 B2 Touring
Nova Scotia
Nova Scotia
- clutch
23 Oct 2008 19:12
Well, the forum reads similar to my post...though someone there posted a link to getting custom cables made by motionpro....looks like my best bet. I will post back after calling them tomorrow about price/time/etc. Thanks for the reply and posting that link!!!
www.motionpro.com/custom/index.php
~Clutch
~Clutch
Wish List:
Wish List:
24 Oct 2008 07:20 - 24 Oct 2008 07:25
Here's some info from postings by Jeff Saunders (Z1 Enterprises) in an earlier thread.
Re: Shortest stock KZ clutch cable? 4 Months, 1 Week ago
www.z1enterprises.com/detail.aspx?ID=283
That is the shortest readily available cable. The Z1R has bars with only a 2"-2.5" or so rise (50mm-65mm).
Motion Pro makes any length you need. We have worked with Motion Pro to make a number of custom cables - some just shorter /longer versions of stock cables, others having different ends where alternate carbs or throttle assemblies are fitted.
Custom cables - depending on what is needed, they range from around $25 up to $50 each.
Good Luck!
Good Luck!
Last edit: 24 Oct 2008 07:25 by Patton.
- clutch
24 Oct 2008 09:22
Oh that's not too bad for price. Bike Bandit was asking $40 for the cable until it said it wasn't available! I haven't called motion pro yet because I found a cable on ebay that will work for me. If I don't win the auction, then I'll go with the custom job.
~Clutch
~Clutch
Wish List:
Wish List:
